KX121 Question
/ KX121 Question #1
Kyle241
Platinum Member
Eastern Ontario
Kubota MX5100
Just curious whether anyone who has a KX121 can provide me with some answers I'm looking for. I'm currently making a trail through a low part of my property and the ground is mostly peat and it's current dry. I have been using my B20 to pull stumps and rough out the trail but thought renting a KX121 would be much more productive. I still have to do:
- widen trail
- remove stumps
- dig drainage ditches on both sides
- install some culverts
Just wondering whether the KX121 would be okay on top of a peat type soil as it's close to 10,000lbs but it is on tracks so hopefully that spreads the weight evenly. I have thought of building my own 'swamp mats' just in case. Also how are they with pulling stumps, note that this is in peat so they come up fairly easily with my B20. Is the KX121 powerful enough to push trees over after tearing out some of the roots?
Tks.
/ KX121 Question #2
Hi I think you will be fine with the KX121! If the stumps are big I will take little longer to get them upp. Personly I wound went for KX080, more reach, more power, easier to operate (well its more self weight which make all the movments more calm) but of course you need to know what you doing;) And I think that the "land pressure" is almost the same, it might even be better on the KX080. If it swampy be careful, ride with your door open and sun roof open if you have one and go slowly. And swamp mats are really good!
Good luck.
/Sam
/ KX121 Question #3
IF you can be there with a B-20 then you can be there with a KX! The speed of all but the trravel it would be a good match for getting the work done faster and some fun to boot!
2022 EZ-GO ELITE...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
211299 (A62131)
211299 (A62131)
2018 Ford F250 4x4 Ext. Cab Pickup Truck (A64194)
2018 Ford F250 4x4...
2015 Chevrolet 15 Passenger Express Van (A62613)
2015 Chevrolet 15...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
