KX121 Question
/ KX121 Question #1
Kyle241
Platinum Member
Eastern Ontario
Kubota MX5100
Just curious whether anyone who has a KX121 can provide me with some answers I'm looking for. I'm currently making a trail through a low part of my property and the ground is mostly peat and it's current dry. I have been using my B20 to pull stumps and rough out the trail but thought renting a KX121 would be much more productive. I still have to do:
- widen trail
- remove stumps
- dig drainage ditches on both sides
- install some culverts
Just wondering whether the KX121 would be okay on top of a peat type soil as it's close to 10,000lbs but it is on tracks so hopefully that spreads the weight evenly. I have thought of building my own 'swamp mats' just in case. Also how are they with pulling stumps, note that this is in peat so they come up fairly easily with my B20. Is the KX121 powerful enough to push trees over after tearing out some of the roots?
Tks.
/ KX121 Question #2
Hi I think you will be fine with the KX121! If the stumps are big I will take little longer to get them upp. Personly I wound went for KX080, more reach, more power, easier to operate (well its more self weight which make all the movments more calm) but of course you need to know what you doing;) And I think that the "land pressure" is almost the same, it might even be better on the KX080. If it swampy be careful, ride with your door open and sun roof open if you have one and go slowly. And swamp mats are really good!
Good luck.
/Sam
/ KX121 Question #3
IF you can be there with a B-20 then you can be there with a KX! The speed of all but the trravel it would be a good match for getting the work done faster and some fun to boot!
2017 Ford E-450 Super Duty Shuttle Bus (A66736)
2017 Ford E-450...
2014 KOMATSU PC170LC-10 EXCAVATOR (A65053)
2014 KOMATSU...
2012 STEPHENS CRUDE PUP TRAILER (A67714)
2012 STEPHENS...
2019 JOHN DEERE 30G EXCAVATOR (A65056)
2019 JOHN DEERE...
2016 Kubota RTV X1140 (A65563)
2016 Kubota RTV...
2014 MAGNUM TRAILER (A68842)
2014 MAGNUM...
