Kx121-3ss thumb power
   / Kx121-3ss thumb power #1
NikonRon
Owensboro, Ky
kubota kx121-3ss mini excavator
How can I increase thumb holding power? Ron
   / Kx121-3ss thumb power #2
If you can locate the AUX valve that controls the thumb, it may have its own
relief valve. Sometimes they are adjustable. If you have an OEM setup, your
manual may have a hyd schematic.
If you want to mess around with relief valve settings, I suggest you get a
pressure test gauge, if you do not have one.
I'll look a bit deeper and see if I can locate the AUX valve. Ron
   / Kx121-3ss thumb power #4
Assuming a cylinder is operating to its full system ability, but is weak, in general, you can go up a size in cylinder diameter, or move the thumb cylinder pin farther from the hinge pin. But the second option would change the thumb swing arc some.
Does yours look like this?
Bruce
It will hold the load if I hold the button but if I release it it seems to back off on pressure. Appears to be OEM Kubota. Ron
   / Kx121-3ss thumb power #6
Just for reference I have a KX91 and if I clamp down with the thumb then let off it continues to hold and does no back off. Sounds like something is leaking down more than you are not getting enough initial pressure. The thumb needs to be set so the bucket can overpower it so the machine does not get damaged.
I need to pick up 1200# rocks and would like for it to hold its grip. Aware that the bucket should be able to push it back which also lets you curl the bucket as you position items. Is there a way to adjust the pressure? Ron
Upon further inspection I have found that it is a USA Attachments after market thumb. Ron
   / Kx121-3ss thumb power #9
Before adjusting pressure you need to check the pressure and see if it is in spec. From what you are saying it does not sound like pressure is your problem, but bleed down is the issue.
Open your cover over the hydro tank - there should be a lever (valve) there on the tank or close to it. This controls the thumb in your case - if it get a little out of position the thumb will bleed off pressure. You normally use this lever to switch between a thumb and a breaker. Check that and see if it helps.
I'll take a look and see if I can locate it, thanks. Ron
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
2002 LULL 644B-42 TELESCOPIC FORKLIFT (A51246)
2002 LULL 644B-42...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
2011 WABASH 53x102 DRY VAN (A53426)
2011 WABASH 53x102...
