kx121-3 does not move
/ kx121-3 does not move #1
nogomo
kubota 121-3
upon arrival, 2005 Kx121-3 burried in 20" plus of snow. some melting had occured as there was ice in places.
started just fine, but the forward, reverse levers do not move. Did not try to force them, as I figured it could be ice.
left it run a while, but no change. Will head back when warmer. any thoughts? thanks
/ kx121-3 does not move #3
Try some wd40 on the cylanders that activate the hydraulic lines that the controls are attached to...On my tractor --front end loader--they have a tendency to stick and I get them working again that way Tony
/ kx121-3 does not move #4
If you did not engage the red safety lever on the left side the track levers will be locked, once the lever is down it will allow you to engage the drive levers. Hope that is all it is, hope this helps.
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
2024 John Deere 333G Tack Loader (A63111)
2024 John Deere...
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2015 Chrysler 300 Sedan (A61574)
2015 Chrysler 300...
