kx121-3 does not move
/ kx121-3 does not move #1
nogomo
kubota 121-3
upon arrival, 2005 Kx121-3 burried in 20" plus of snow. some melting had occured as there was ice in places.
started just fine, but the forward, reverse levers do not move. Did not try to force them, as I figured it could be ice.
left it run a while, but no change. Will head back when warmer. any thoughts? thanks
/ kx121-3 does not move #3
Try some wd40 on the cylanders that activate the hydraulic lines that the controls are attached to...On my tractor --front end loader--they have a tendency to stick and I get them working again that way Tony
/ kx121-3 does not move #4
If you did not engage the red safety lever on the left side the track levers will be locked, once the lever is down it will allow you to engage the drive levers. Hope that is all it is, hope this helps.
1998 Fontaine 48ft. 38 Ton T/A Flatbed Trailer (A61573)
1998 Fontaine...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2017 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A61572)
2017 Takeuchi...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
RoGator and Terragator Manuals (A63117)
RoGator and...
