Kuhn any good? EL35-130 tiller
   / Kuhn any good? EL35-130 tiller #1
Big Hammer
I found a used Kuhn model EL35-130 around 4.5’ IIRC, but I’m concerned about parts quality of construction and availability. It’s only 488 pounds which seems light.
I cant seem to find anything when searching google
thanks 😊
   / Kuhn any good? EL35-130 tiller #2
Kuhn builds some of the best built tillers today, much better than a lot of the light duty all the way to junk I see being sold.
I don't know anything about that specific model though.
SR
   / Kuhn any good? EL35-130 tiller #3
I found a used el43 several years ago. They’re expensive compared to a lot of Chinese low quality equipment, but well built in france.
   / Kuhn any good? EL35-130 tiller #4
I had a Kuhn tiller. It was excellent
Andy
   / Kuhn any good? EL35-130 tiller #5
I have that exact one.
Bought used about 20 years ago.
I rototill about an acre of garden spring and fall and do similar for a couple neighbors.
I'm **** about greasing things and maintaining gear oils.
After all this time there are a couple blades need replacing. It has hit a rock here and there.
The others are showing normal wear.
For what I do I'm resisting replacing the whole set as they are pretty pricey.
Other than that no problems. At least around here parts if needed are available.
Only thing is my tractors are a little wider, so if I set it up to cover one side totally I have to slightly overlap the return trip to get complete coverage.
I'd get another in a heartbeat if I needed a tiller.
   / Kuhn any good? EL35-130 tiller #6
If you cut hay, you'd know what KUHN was all about. They are good, right there at top notch best level.
   / Kuhn any good? EL35-130 tiller #7
Nearby rental place has Kuhn tillers, as they've found them really be able to take a beating.
   / Kuhn any good? EL35-130 tiller #8
I don't have one. We have an old LONG 8' tiller that still does good. But, I have seen KUHN tillers and they do just fine. I have rebuilt some hay mowers, complicated as Chinese arithmetic, but still good.
2018 Doosan DL220-5 Articulated Wheel Loader (A56857)
2018 Doosan...
2024 AGT LRT23 Mini Stand-on Track Loader Skid Steer (A56857)
2024 AGT LRT23...
(1) HD 20ft Free Standing Corral Panel with Feed Bunk (A57453)
(1) HD 20ft Free...
2025 Unused SDLGC80 60v Electric Golf Cart (A56859)
2025 Unused...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A56858)
2013 International...
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58216)
2019 ALLMAND...
