Kuhn any good? EL35-130 tiller
   / Kuhn any good? EL35-130 tiller #1
Big Hammer
I found a used Kuhn model EL35-130 around 4.5’ IIRC, but I’m concerned about parts quality of construction and availability. It’s only 488 pounds which seems light.
I cant seem to find anything when searching google
thanks 😊
   / Kuhn any good? EL35-130 tiller #2
Kuhn builds some of the best built tillers today, much better than a lot of the light duty all the way to junk I see being sold.
I don't know anything about that specific model though.
SR
   / Kuhn any good? EL35-130 tiller #3
I found a used el43 several years ago. They’re expensive compared to a lot of Chinese low quality equipment, but well built in france.
   / Kuhn any good? EL35-130 tiller #4
I had a Kuhn tiller. It was excellent
Andy
   / Kuhn any good? EL35-130 tiller #5
I have that exact one.
Bought used about 20 years ago.
I rototill about an acre of garden spring and fall and do similar for a couple neighbors.
I'm **** about greasing things and maintaining gear oils.
After all this time there are a couple blades need replacing. It has hit a rock here and there.
The others are showing normal wear.
For what I do I'm resisting replacing the whole set as they are pretty pricey.
Other than that no problems. At least around here parts if needed are available.
Only thing is my tractors are a little wider, so if I set it up to cover one side totally I have to slightly overlap the return trip to get complete coverage.
I'd get another in a heartbeat if I needed a tiller.
   / Kuhn any good? EL35-130 tiller #6
If you cut hay, you'd know what KUHN was all about. They are good, right there at top notch best level.
   / Kuhn any good? EL35-130 tiller #7
Nearby rental place has Kuhn tillers, as they've found them really be able to take a beating.
   / Kuhn any good? EL35-130 tiller #8
I don't have one. We have an old LONG 8' tiller that still does good. But, I have seen KUHN tillers and they do just fine. I have rebuilt some hay mowers, complicated as Chinese arithmetic, but still good.
2022 Chevrolet Express (A50120)
2022 Chevrolet...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
Frontier AV50H Hydro Grapple (A50120)
Frontier AV50H...
2014 Freightliner M2 106 Ambulance (A50323)
2014 Freightliner...
Caterpillar CB-34 (A50120)
Caterpillar CB-34...
