kubotaB7100D loader
/ kubotaB7100D loader #1
doktorslo
if there is anyone who knows the model number for the loader that goes with a 1979 b7100d i surely need it to order a cylinder for it. cant imagine kubota would have made more than one model for that tractor.
/ kubotaB7100D loader #2
If I remember right, my B7100 had a Kubota 1630 loader on it. It was not an easy on -- easy off rig, no QA bucket either, but it was a very good fit for the tractor and a very strong (for it's size) little loader.
Welcome to the board. If I was you, I would check in at the Kubota forum, too, if you haven't already done so.
/ kubotaB7100D loader #3
I'm pretty sure my 7100 HST has the 1630 loader as well. I did some research a while back and found 3 possible kubota FEL. the 1630 was the only one that did not have any "easy on easy off" setup. Also depending on whats wrong with the cylinder it could be a lot cheaper to have the seals replaced.
As soon as time premits I need to do the same to my old loader. If you do the work yourself I understand it can be done for about 30 bucks each. I've also noticed the seals in my loader valve are leaking more then the cylinders. You might want to look at the valve before ordering new cylinders as well.
/ kubotaB7100D loader #4
I think my b7100d tractor is about the same age (serial number 59680) and it came with a b219 loader. Runs off a front PTO pump with the reservoir in the right hand upright, round back bucket.
Its getting dark but I grabbed a few pix, will post here shortly.
Charles
/ kubotaB7100D loader #5
Here are the pics of my b219 loader on a kubota b7100d
Charles
/ kubotaB7100D loader #6
I'm thinking those may be aftermarket hydraulic cylinders. Try a shop that does hydraulics and see what they say.
/ kubotaB7100D loader #7
My 1978 B6100 has the Kubota B219 loader just like Charles' B7100.
My FIL is the original owner and I got it from him. The cylinders may look aftermarket because they're not painted Kubota orange but they're original.
I have a leak in one of mine and got the re-packing kit from tractorsmart who advertises/posts here. Looks like a pretty straight forward repair if I can figure out how to remove the snap ring holding it together. The snap ring that came with the kit isn't like any snap ring I've ever seen. It's hard steel and has no "snap" to it at all plus it's as big around as the cylinder so normal snap ring pliers won't open wide enough. Until I come up with a plan of action to get the snap ring off, I'm just living with the leak.
doctorslo - what's wrong with your cylinder?
WVBill
/ kubotaB7100D loader #8
My 1995 B7100 had the B1630C loader, but the tractor he asked about was too early a model for the 1630 loaders.
/ kubotaB7100D loader #9
When I traded mine in at a Kubota/Case dealer, they weren't sure what year it was. It had no ROPS when I got it, and the guy who picked it up wondered about the color of the non-orange parts of it, which were kind of a blue-gray. I don't know what year it was, but it was pretty old. The pick-up guy wondered if it might have been gray market since they couldn't find the SN in their books and it was on the wrong part of the tractor. P.O. said it was from a dealer on the south side of Akron, Ohio in Springfield Township, that's out of business now.
THANK U SO MUCH. if my exhaust wasnt mounted horizontally, instead of vertically like yours, i'd swear it was the exact tractor! if i hadnt noticed the vertical exhaust in your pics, i'd be out to the barn to make sure mine was still there! i even see similar scratches and wear on the loader,etc.
i've had the same problem w/ the sn being funky in some way. my cylinders are also blu-gray, and i know its original. charles sent pics and his are trhe same color, and the loader is identical. the people on this website are awesome.
you guys are all awesome. charles' pics did the trick. THANKS!
leaks(insufficient adjective) pours hydraulic fluid from the rear end of the lift cylinder. i'll try tractor smart. if anyone comes up w/ a way to remove the snap rings that would be really great.
/ kubotaB7100D loader #14
My exhaust was horizontal, but it's pretty easy to switch it to vertical, which I did.
/ kubotaB7100D loader #15
I have what looks like an original owners manual for the b219 loader. It shows the four hyd cylinders and the bucket as being 'not orange' (black and white photo) so the blue-gray color is original.
I don't know if Kubota made the later model loaders but if I recall correctly mine has a plate on the inside of the left upright saying it was made by some company in the midwest.
Charles
what's the advantage in vertical vs horiz?
/ kubotaB7100D loader #17
Afternoon doktorslo.
"what's the advantage in vertical vs horiz?"
Maybe less exhuast smoke blow back in your face,also no exhuast smoke on loader arms to clean....but don't forget about objects that hang low. :(
/ kubotaB7100D loader #18
I'm sure it probably depends on just which model you get, but when I bought my 1995 B7100, it originally had the horizontal exhaust, but the dealer said they had to turn it to vertical to add the B1630C loader.
/ kubotaB7100D loader #20
Not knowing exactly what your snap rings are- I'd guess they are flat spring steel, about 2 coils worth. If this is the type and If you look closely, you can find an "end" to the spring. Pry it out with a small bladed screw driver and work the spring( you'll probably need two instruments to do this) around the circumference of the cylinder till it pops out. To replace, insert one edge of the coil into the groove and work the spring around the groove.
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2014 CATERPILLAR 938K WHEEL LOADER (A65053)
2014 CATERPILLAR...
2022 EZ-GO ELITE...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
2023 TEXLINE BOBCAT HAULER (A65643)
2023 TEXLINE...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
