Kubota
/ Kubota #1
Rdavis
8200 runs hot cleaned radiator fluids full any ideas
/ Kubota #4
Welcome to TBN Rd..
The more information you give us, the more inclined we are to think about your issue.
The tractor is how old ?, how many hours on it? , used for ?, problem first noticed when you ?, this was after you ?
With none of the above info:
*dirt in radiator fins, * bad waterpump impeller, *loose fan belt, *bad thermostat, * blockage in radiator, * head gskt failure..etc.
/ Kubota #7
Every summer I have to drain the 50/50 anti-freeze mixture out of my B7800 and put in just water. If I do not change it will run over into the red when I am cutting with the bush hog for more than an hour. As soon as I change out the anti-freeze I can run the bush hog all day and not go into the red. It does not cost much to try it.
/ Kubota #8
Replace the radiator cap first. A non pressureized system will run hotter.
/ Kubota #9
You can't be putting a 50/50 in or it would run cooler Straight antifreeze will probably boil over before water.
Water will boil over before properly mixed antifreeze.
/ Kubota #10
All I can tell you is what the gauge tells me. When I drain the system in the summer and put in straight water, the gauge says that I am running cooler.
Like I said it does not cost much to try.
(2) 13.50x60 Tires and Rims (A65640)
(2) 13.50x60 Tires...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2024 Deere 320G (A64126)
2024 Deere 320G...
2013 FORD E-350 11 PASSENGER VAN (A65643)
2013 FORD E-350 11...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2017 TROXELL 150...
2010 Chevrolet Express 3500 Dive Team Cargo Van (A64556)
2010 Chevrolet...
