Kubota Zero Turn Starting Issue Z125S
   / Kubota Zero Turn Starting Issue Z125S #21
Yes, starter was bench tested before i installed it
So if I understand you correctly, you are saying that the started spins when not under load on the bench.
That does not equal the starter working under load.
Richard
   / Kubota Zero Turn Starting Issue Z125S #22
To Wrap Up. "When I Turn the key, sounds like the "PTO" clutch solenoid clicks" (this was not PTO, it is the fuel shutoff solenoid)
I never stated that the starter was LOAD tested on the bench. I stated that I bench tested (meaning. powered, spun, and the gear moved such that it would engage) Perhaps next time I'll be clearer.
Here's what i deduced. 1) The remote starter, albeit a "good" one, did not have super heavy cables. It may be more designed to power through a relay. That is likely the reason the engine would not turn over with its use. 2) the 'ol screwdriver over the starter solenoid finally started the engine. If i were smart, I'd rewire with a new relay as advised by gator6x4. good advice. 3) finally found that the "brake" safety switch was bad. Getting good at replacing this. 3rd one in 6-7 years...nuff said. Thx.
2011 Chevrolet Traverse 1LT SUV (A55758)
2011 Chevrolet...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
2006 International Bucket Truck (A55973)
2006 International...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
