stevenmartinwv
- Joined
- Aug 24, 2024
- Messages
- 3
- Tractor
- Kubota ZD326 Zero Turn Mower
Have a ZD326, 445 Hours. Noticed that the fuel gauge was not working. Temp gauge not working either. Pulled the Left Tank fuel sensor, no corrosion or obvious problems. Float seemed sound. Connection terminal and ground seemed OK. Any idea if these fuel sensors (K3181-62150) ever short out internally? Checked the fuse box and the center fuse slot in the photo, marked “Main System”, had a 15 amp blown fuse. But it blows a new fuse immediately when you try to install a new one. Any ideas about why or where this circuit seems corrupted or shorted out? Machine starts and runs just fine. But the temp and fuel gauges are just not working. Looking for some advice on just how to proceed to find this circuit fault. If it will accept a new fuse, I believe both guages should start working again. Thank you. Any insights or other things to check would be most appreciated. Photo below: Blown fuse removed from faulty circuit.
