Kubota won't start
/ Kubota won't start #1
sigelgolf
Sigel, Pa
Kubota B2910
I own a Kubota B22910 and it won't start. I checked the interlocks and they seem OK. The battery is new. The lights, signals, etc. all work, but there is no sound coming out of the start position...dead. I have a manual and it says it could be one of the three safety switches: clutch; pto; hst????:confused::confused:
/ Kubota won't start #2
Welcome,get a meter and check your safety switches to make sure they are working then go from there.
/ Kubota won't start #5
Kubota won't start if PTO is engaged.
/ Kubota won't start #6
Sometimes, I have found that I think the PTO is in the off position but mine won't start. I then jiggle the pto lever to assure it is in neutral and that usually works. Sometimes it is the HST pedal is not quite in the neutral position. Assure those are in proper position and be sitting on the seat. Once the wire for the starter relay came loose while I was clearing brush in the woods.
I hope it as simple as that. But check them first.
