Comparison kubota vs scagg
/ kubota vs scagg #1
rpj30525
clayton ga
kubota
i am trying to decide which one. if anyone could help that would be great thanks
/ kubota vs scagg #2
I think you will be very happy with either ! Skag is top of the line, used by lots of pros. I had a freedom Z, more of a high end homeowner machine,did a great job but I just traded it for a Kubota ZD-221. It just came in today but I haven't picked it up yet.
/ kubota vs scagg #3
It's hard to beat the Kubota for longevity and quality of cut.
/ kubota vs scagg #4
I can't speak for now, but 4 years ago when I bought my Scag I did a lot of research. Seems the Kubota blade tip speeds weren't as much as some of the other ZTRs and at the time some were having problems with the Kubota hydro. I have been super happy with my Scag Wildcat. But I frankly have not heard anything negative about the Kubota quality of cut.
/ kubota vs scagg #5
I can't comment on the Kubota mower; never drove or mowed with one. I have a Scag Tiger Cat and a Kubota B2920. Love the Scag for mowing. FAST, clean cuts. Stable. Biggest downside to zero turns is that you sit a little lower, blade tip speeds are higher, and you can get dusty/dirty real quick. Also, if your terrain is not smooth, I would want a suspension seat. Never had a bit of trouble since I bought mine new in 2010. Regular maintenance-oil, filters, both air and oil and lubrication. Keep the tires at the right pressures. Blow the Scag off with a Stihl blower. Never wash with a pressure washer; might do some damage.
/ kubota vs scagg #7
rpj30525,
What did you end up buyimg?
/ kubota vs scagg #8
I shopped around and ended up buying a kubota zd331
/ kubota vs scagg #9
We bought a Scag for the church back in about 1980ish. It was a good one and easy to work on. Could remove all 3 blades in about 5 minutes. Took about that long to put them back on after sharpening.
Can't you get a diesel Kubota though? Not sure Scag makes a diesel. Know a mower tractor type Kubota came in diesel not long ago.
Ralph
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
2009 CPS Manac SGH36 Hopper Bottom (A64047)
2009 CPS Manac...
2023 LandMaster L7 (A62183)
2023 LandMaster L7...
Reynolds 18yd Dirt Pan (A64047)
Reynolds 18yd Dirt...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
LOT OF U CHANNEL TRUCK BLOCKING (A63745)
LOT OF U CHANNEL...
