Kubota vs Mahindra
/ Kubota vs Mahindra #1
knightj
I have been looking for a 60(ish) horse tractor for a few months and have narrowed the search down to the Kubota M6800 and the Mahindra 6500. Both models with 4wd and FEL. The Mahindra is around 4,000.00 less than the Kubota, and Mahindra is new to the area. Is there anyone out there who has had a Mahindra for a few years ?
This is also the first time I have purchased a new tractor and I'm not sure how much mark up a tractor typically has. I haven't done any serious face to face negotiating, but the Kubota dealer is not budging much. I have a 2510 Long 2wd with a Bush Hog FEL only 625 hours that I would like to trade in. I have a price of 18,000 and my tractor from Mahindra and 22,000 and my tractor for the Kubota. Does this sound reasonable ??
/ Kubota vs Mahindra #2
There are a few things that are going to make the kubota more expensive - the transmission for one. Its a 8x8 shuttle, usually hydraulic clutchless vs an 8x2 gear drive. Generaly there is about a $1600 cost difference here when you have both options on the same machine. Mahindra lists 11gpm for the hydraulic system, i assume this is total output since they don't say. The M5700 has 17.1 gpm, end result is that your implements will cycle much faster and you have enough flow to run hydraulic motors. Again, a cost difference here. You'll also find that the kubota loader will out lift the Mahindra by a small margin at both the loader and 3pt. You don't find these things on spec sheets, but it looks as if Mahindra is not using plantary front axles, wet breaks, and a hydraulic PTO - otherwise they would point these things out. To give credit where credit is due, the 6500 does have more engine Hp and is heavier if thats what your looking for. In summary, there is usually a reason when Kubota is not within a few hundred $$ of any competition. Tractors like the MX5000 would be much more compriable, however right now the standard series AG tractors stop at 50Hp.
/ Kubota vs Mahindra #3
I'm not sure what Messick is trying to say, but the 6500 Mahindra 4WD does have 8 X 8 shuttle shift, combined with a completely syncro trans; it does have wet brakes; the hydraulic system is 11 gals/minute, but it has a separate hydro pump for the steering (I think about 5gal/min for that one). For those interested in the technical side, the hydro pumps are tandem units--one hooked right behind the other. And, oh yeah, the front axle on the 6500 is planetary (designed by Antonio Carraro of Italy). I'll stop there for now, but don't let someone pass off any tractor as better than another before you get the straight stuff. BobG in VA
/ Kubota vs Mahindra #4
I stand corrected, I spent several minutes on their website looking over the details and I came away with a rather different impression.
/ Kubota vs Mahindra #5
If Bob is correct, and I have no reason to think he's incorrect, Mahindra needs to update their specs for the 6500 on the website ( 6500 Spec Sheet ). It lists the following in contradiction to Bob's statements:
Transmission: Constant Mesh, 8 forward, 2 reverse (is that the same as shuttle shift?)
Brakes: Fully enclosed dry disc
Hmmm...
[EDIT] Ah... Now I see... If you look at the top part of that spec sheet, it does list 8x8 shuttle shift, wet disc brakes, and independent PTO as standard on 4WD models.[/EDIT]
BR
/ Kubota vs Mahindra #6
Yes, as the M6800 is a 4WD (I assume thats the case), it wouldn't be right to rank a 2WD against it. When Messick mentioned Planetary gears he had to be talking about 4WD so that's why I responded. BobG in VA
/ Kubota vs Mahindra #7
Have done the research on 35hp,4wd, went with Mahindra. Due to the weight of the tractor. Check out the weight difference between the two.
/ Kubota vs Mahindra #8
im sorry, but an mx5000 is cool as heck but not in the same class as a 6500 4wd. he is right to compare the bigger kubota to the 6500.
Anybody out there that has had 1-3 years experience with the Mahindra ?? I will be cutting 70acres of Hay and feeding 5x5 rolls of hay in the winter, plus other general uses.
/ Kubota vs Mahindra #10
i have a 4500 2wd and it could handle that, i wouldnt be able to run a large round bailer but the 6500 can. you could easly handle 1500# round bails without any counter weight on the back. i think the m5700 is a 50hp so you might want one size up in hp to run a round bailer in kubota.
/ Kubota vs Mahindra #11
Yeah, I've had a 6000 4WD for almost 3 years. It has 16.9 X 28 filled rears, and 11.2 X 24 fronts. Toothbar on the bucket. You won't have any problem with a 6000 or larger Mahindra doing anything you need to do. They are relatively low compression (19.4:1), low rev (2100 rpm) high torque engines. If you get an FEL, do yourself a favor and have the rears filled before delivery. Shouldn't cost much over $75/tire and you then have 1400 or so extra #s in the a$$. BobG in Va
/ Kubota vs Mahindra #12
We recently went through the same process of comparing a Kubota M6800 to a Mahindra 6500. Both tractors were sold by the same dealer (which also carried NH). We came away with the Kubota. The Kubota felt smoother and more refined. The cockpit fit us better and the tractor felt 'right.'
We asked the folks in the garage if they had any problems with the Mahindra - minor or major and the answer was no. The Mahindra was a solid performer. A couple guys didn't like the sound of the motor but that was about the only negative thing they had to say about the tractor.
The weight difference between the two tractor is a non-issue for me. Adding ballast is easy and allows you to put it where its needed most.
In the end, it is up to you to drive the tractor and find out if it does what you want. Figure out if your dealer is going to be there for you in the long run. Then buy the tractor that suits your needs and budget.
I honestly don't believe you'll go wrong with either machine. We were more comfortable with an orange tractor. Your results may vary.
In the end, it will be your tractor. Buy what is going to serve you well now and in the future.
/ Kubota vs Mahindra #13
I’ve been looking at green blue orange and red in several brands. Drove a Mahrinda 2015 not long ago (unfortunately they didn’t have a hydro on the lot so can’t comment there) but the loader was far more impressive than KUB and NH, haven’t tried a green one. I like to dig with a loader, the Mahrinda had a good amount of travel downwards after contacting the ground with the bucket flat. The OEM Kubota and New Holland’s you’ll have to tilt the bucket forward in order to drive down past ground level. If digging depth of a front loader is important, IMO that is a consideration. Also noticed the speed at which the loader moved was startlingly fast. The depth of bucket and angle of the sides will also control how deep you can dig, the NH would probably win there. If the aftermarket loaders have the ability to drop below ground level with bucket flat I haven’t gotten to yet.
Not seen much comment on the mowers compared and that is one thing I would love to see an in depth analysis on all brands....that is, a comparison of likes/dislikes of all brands of MMM’s side and rear discharge.
I agree with Messick on one thing, you develop a feel for machinery as years and experience go by and can instantly feel minor things most people would never notice. I’ve spent considerable time on various machines throughout my life, including many varieties of race cars and race karts as well as having worked a time rebuilding engines including racing engines and diesels. All those things come together without you even realizing it and if you state an opinion that seems clear to yourself, others without that experience or “ear” simply can’t relate and often do not believe. There is no teacher of engine noise and harmonics like running over 115 MPH at Daytona on a racing kart that’s cranking 12,500 RPM.
/ Kubota vs Mahindra #14
Get the Kubota. Resale will be super. Plus I feel Kubota is the best tractor company going right now. Deere is the best for "big" tractors. And Kubota takes care of the "little" tractors. The quality of Kubotas speaks volumes. If Toyota was to build a tractor...it would be like a Kubota. Have fun with your new tractor!
/ Kubota vs Mahindra #15
I posted message 827704 in the wrong thread. If someone can delete it that would be good.
I went with the Kubota 6800 4x4 with the FEL. I will try and post a review after hay season. Thanks to all who posted. This is a great site.
/ Kubota vs Mahindra #17
Which loader did you get for the M6800?
VH4D Wisconsin Engine (A65640)
VH4D Wisconsin...
LANDPRIDE RCR1872 - 6' ROTARY MOWER (A64277)
LANDPRIDE RCR1872...
2017 Hyundai 53' Dry Van Trailer (A62613)
2017 Hyundai 53'...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
