kubota vs. kioti
/ kubota vs. kioti
I've had the opportunity to own both a kubota L3200, and a kioti ck35 recently. I've got to say that the Kioti is much more a better machine to me than the same priced kubota. There is just no comparison. The Kioti is like a tank compared to the kubota a toy. The Kioti brings so much more tractor to the table. The Kubota has a defective 3pt. lift, the Kioti works right.
I can only share first impressions, but very impressed with the ck35.
As a former {retired} Kubota and Kioti dealer, yes Kubota did everything they could do to stop selling Kioti's, they finally took the Kubota contract away from me. I was pissed for a long time, and finally realized that they did me a favor. Kioti is hands down better than Kubota. Kubota uses psychology and advertising to get people to buy their product. It cut my shop work down by at least 80%, which I wanted. Sell a Kioti and it rarely comes back for any problem. I think, as a rule, any Korean tractor is built heavier and better than a Kubota. In 34 years selling tractors, you learn a thing or two!
Here we go again!
/ kubota vs. kioti #343
Mid-90s I moved from downtown out into the country on our 20 acres. A good friend told me I'd need a substantial tractor; he loaned me his Kubota (ca 30+ hp; dont remember the model number). By the way, that could be a really good definition of "good friend," someone who will loan you his Kubota. His advise: "Don't kill yourself, and don't knock down the house." Good advise. After a few months I was fully convinced. Went tractor shopping. Found a Kioti 3024 for several thousand (maybe 4000?) less than the similar Kubota. Have been using it ever since for every conceivable sort of task. My conclusion: they are both excellent machines, but the Kioti is a lot more tractor for the dollar. Then too, Japan has some pretty significant neighbors to the north.
/ kubota vs. kioti #344
I haven't read the entire thread, but has anyone ever compared fuel efficiency between Kioti and Kubota tractors? The only reason I mention it is because of the better fuel efficiency I'm getting with my CASE ctl when compared to the Kubota SVL75. The CASE is a stronger and larger framed machine with 10 additional net horsepower. Fuel consumption between the two machines is huge.
/ kubota vs. kioti #345
RD, this is not a scientific test, but my L3800 and DK35se with nearly the same size engines, and nearly same horsepower (Kioti 2 more) seem about the same to me fuel wise. Again not very scientific. The Kioti seems to have a little more "torquey" low end. This is just an impression. But I noted the 2nd day I had the tractor, I looked back at an old thread. They both go a long ways on a tank of fuel, and the amount of work they can do on a tank of fuel is nothing short of amazing. Especially if you have to compare it to what you can do with a shovel.:laughing:
/ kubota vs. kioti #346
/ kubota vs. kioti #347
What is the price difference of say a proven heavy built tractor like a Massey Ferguson 2615 vs a Kubota or Kioti? Would be hard for me to pass on a stout MF with large bore Diesel engine, huge rear end, and very low torque curve. Look at the PTO speed. Full torque and hp comes on very early too. image-3219691903.jpg
/ kubota vs. kioti #348
Thanks James. The only way I could get halfway decent fuel use out of the Kubota was to set the hand throttle at about 1500rpm and use the foot throttle under heavier loads. When I set the hand throttle at about 2000rpm the low fuel warning would let me know when I was getting close to 8 hrs. It has a 24 gal tank. In comparison, my CASE sips fuel. I have yet to put more than 17 gallons in it after an 8 hour day. The CASE is a lot stronger in every way, and a lot more comfortable too.
I never liked Kubota tractors much, but I was a fan of the ctl's. Not so much anymore. I do like their mini-excavators though...great breakout power.
/ kubota vs. kioti #349
I don't know why I typed L3800 . I had an L3400... not much difference in them though.:)
/ kubota vs. kioti #350
With a Bobcat CT235 I was getting a little over 1 gal an hour. It was 34hp and over 4000lbs.
With the L4240 I am getting .75 gal per hour. It is 44hp and a little under 7000lbs. Most of the time the a/c is on too.
/ kubota vs. kioti #351
That's about what I get out of my Kioti doing loader work with the backhoe on, throttle set about 1800.. a tick over 8k pounds..a couple thousand in the bucket...10k:shocked: if I run it at 2k or more doing loader work it will use a gallon an hour.
I haven't done any PTO work with it yet so I don't know what it would use at sustained PTO speed.
/ kubota vs. kioti #352
I only did PTO work 1 time with both tractors and that was pulling a 5' rotary cutter.
I mostly do some sort of loader work or some grading. Even pushing snow it is right around .75gph. I think the auto throttle advance and dual speed hydro help reduce the fuel consumtion.
/ kubota vs. kioti #353
Conditions and how the tractor is operated affect the fuel economy alot. If just putting around, doing a little digging, shuttling some trailers, etc. You dont burn much. Probably the thing I do that consumes the most fuel is using the bushhog. ITs quite a PTO load especially with a 6' cutter and gearing to go about as fast as I can. I can do an 8hr job and barley squeeze in a 6 gal can. SO thats about 3/4 gal/hr under my heaviest use with my L3400. Which is 29HP PTO, and with the loader, hog, and loaded tires weighs in at 5000lbs or a tick more.
/ kubota vs. kioti #354
Thats astounding. Full power should use about twice as much. I often use over 3/4gph mowing with the BX1500.
larry
/ kubota vs. kioti #355
larry
That certainly seems like alot.
I know I have never been over 1 gallon/hr. But then again, I dont always check. But I do kinda keep tabs when bushhogging, so I can track my expenses/deductions etc.
Does your BX have an electronic tach? OR an RPM compensated tach. Cause I typically run over the rated PTO speed by 200-300RPM. Which would tick up hours a tad faster than an actual hour. But it is still pretty good none-the-less.
Heck, plowing snow with my 05 dodge diesel, I have never done worse than 2gal/hr while actually plowing. And on some lighter 2-3" fluffy snows, have even done as good as 1.5gal/hr. Which I thought was pretty good, cause it just "feels" like I have to give it more pedal pushing than running down the highway. But running down the highway with the plow on and ballast, I get ~10-12 MPG @ 65. Which would be like 5-6 gal/hr:confused2:
/ kubota vs. kioti #356
I set the throttle at full stop and take off. The BX holds rpm very well with load and I know its peaked out when it starts to bog a bit. It continues to pull well on down, but I try to hold it at the 1st point barely into bog. Mowing varies a lot. Sno throwing is easy to hold bog in deep sno with the HST. I was running 1hr/pass [real clock time] on our 1mi drive in 16" heavy dense stuf. I put 2G in after every round trip. The 4.5G tank had me worried on pushing to 2 RTs.
/ kubota vs. kioti #357
A second trip would have me worried too.
I know the fuel gauge isnt real accurate in my L3400. Can fill her clear full, (9 gal I think) and work half a day and it dont move at all. Then when it does, it drops rather quickly. Once at or near E, it takes 6 gals and its full again. I have worked it 3 hours before with it resting on E. Still only took 7.5-8 gallons or so.
I know I can pretty much work a full day, doing whatever with it, and not have to worry about fuel til the end of the day (provided I topped off at the start of the day).
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
2010 Freightliner M2 106 Pac-Mac KBF 20H Forestry Grapple Truck (A66736)
2010 Freightliner...
2025 Auger with Bits Mini Skid Steer Attachment (A66734)
2025 Auger with...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
2008 THE MACHINE CO. THAWZALL H250 HEATER TRAILER (INOPERABLE) (A67714)
2008 THE MACHINE...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
