kubota vs. kioti
/ kubota vs. kioti #261
I think I read this same post on a Dodge forum a while ago. Replace Kubota and Kioti with Dodge and Ford and it may be word for word. Even the Toyota reference.
/ kubota vs. kioti #262
I will agree that putting the HST response in a menu instead of a knob, does seem like a step backward, but perhaps they felt that most people just picked a response and stayed with it. At least you get to choose a response with the Kubota. Another example are the heat and air controls on my 2010 chevy silverado. Stupid up and down arrows for temp and fan speed.. It would have been a lot better to have a knob that you don't even really have to look at while driving down the road.
Typical Japanese 90s technology. Nice shoes!
Fred
/ kubota vs. kioti #264
Do some people have problems with reading comprehension? To my knowledge, no tractor manufactures are making tractors with 10-15k rpm engines.
I'm just picking a bit and poking fun. Kubota actually makes a high quality product which is why they sell what they do. I was just reviewing the specs and the M series actually has larger displacement engines for their size which should produce good torque. I stand corrected! Now back to Ford or GM. Lol
/ kubota vs. kioti #265
My Cubota rig has 10% more horsepower than my brother's Kioti tractor but I doubt it can pull like the Kioti. Toque vs HP?
It does do what I want it to do though. :)
/ kubota vs. kioti #267
This was actually legit. This was happening back when I was on the Tundra Forums ...
It wasn't a long pull by any means, but it did actually happen.
300 yards across a bridge
/ kubota vs. kioti #268
Items Toyota failed to tell us: Went downhill on 2% grade with 30mph tailwind all while using 4x4 low range with transmission failing in middle of pull so they had to coast last 50 yards. :)
/ kubota vs. kioti #269
If you have all 4 wheels spinning, no matter who made it, it comes down to weight and tread design.
/ kubota vs. kioti #270
True.
A quick look out on Youtube shows that enough sport bikes got wrapped around trees and enough old, garden tractors are sitting around, that people are making some silly things out of the two.
/ kubota vs. kioti #271
IT has nothig to do with torque vs horsepower.
It has EVERYTHING to do with machine size, traction and gearing.
A small 70 or 80hp tractor with a few hundred ft-lbs or torque has more pull than a 400hp/800ft-lb new diesel 1-ton. Its all about weight, geating and traction. Nothign at all to do with the motor.
/ kubota vs. kioti #272
maybe I should have used a few more smiley faces in my post. :) :) :) :)
/ kubota vs. kioti #273
My reply would have been the same.
Too often people want to compare a tractor engine to a mower by referencing how much they can pull/tow.
And it has nothing to do with that. Think of it this way. A small 27hp kohler or honda or briggs or (pick your poison) zero turn or other mower. Now compare that to something like a 20hp tractor with a bigger engine and a mower deck. The ZTR will power through tougher thicker taller grass at a faster rate. Regardless or torque difference.
The engines (amd machine) are geared for different things. A tractor is geared for pulling. And has the weight and traction to maximize that.
/ kubota vs. kioti #274
Okay, who wants a trip back to high school physics? Here's a problem for you to solve:
How fast can a 4400 lb (2000 kg) tractor go up a 30 degree incline powered by an engine with performance shown in the attached graph? The graph is for a an actual Kubota engine that produces 50 hp (@2700 RPM) and 110 lb-ft of torque (@1600 RPM). Let's assume the tractor has a 12 speed, geared transmission that can cover the range of 1-12 mph, and it is lossless. Let's also assume that road friction is negligible. I recommend you use metric units for the calculation, and then convert the answer to mph at the end. (It's much, much easier that way.)
To save you some time looking for your old text books, here are some hints:
1. The work performed is equal to m * g * h, where m is the mass of the tractor, g is the acceleration due to gravity (9.8 m/s), and h is the vertical height the mass is lifted. Work is measured in joules (J).
2. Power (P) is the rate at which work is performed. It is measured in W (watts), which is the same as J/s (joules per second). P = (m * g * h) / t, where t is time.
3. For a 30 degree incline, the distance traveled is double the height the mass is lifted.
and some conversion factors:
1 m/s = 2.24 mph (velocity)
1 HP = 746 W (power)
1 kg = 2.2 lb (mass)
1 N-m = .74 lb-ft (torque)
It shouldn't take more than a few minutes to come up with the answer.
Cheers
/ kubota vs. kioti #275
Okay, who wants a trip back to high school physics? Here's a problem for you to solve: How fast can a 4400 lb (2000 kg) tractor go up a 30 degree incline powered by an engine with performance shown in the attached graph? The graph is for a an actual Kubota engine that produces 50 hp (@2700 RPM) and 110 lb-ft of torque (@1600 RPM). Let's assume the tractor has a 12 speed, geared transmission that can cover the range of 1-12 mph, and it is lossless. Let's also assume that road friction is negligible. I recommend you use metric units for the calculation, and then convert the answer to mph at the end. (It's much, much easier that way.) To save you some time looking for your old text books, here are some hints: 1. The work performed is equal to m * g * h, where m is the mass of the tractor, g is the acceleration due to gravity (9.8 m/s), and h is the vertical height the mass is lifted. Work is measured in joules (J). 2. Power (P) is the rate at which work is performed. It is measured in W (watts), which is the same as J/s (joules per second). P = (m * g * h) / t, where t is time. 3. For a 30 degree incline, the distance traveled is double the height the mass is lifted. and some conversion factors: 1 m/s = 2.24 mph (velocity) 1 HP = 746 W (power) 1 kg = 2.2 lb (mass) 1 N-m = .74 lb-ft (torque) It shouldn't take more than a few minutes to come up with the answer. Cheers
I need another beer first. :)
/ kubota vs. kioti #276
I didn't use metric, and not sure if it works out the same, but here is what I did.
The fundamental definition of a HP is 33000 ft-lbs per minute. Or the ability to lift 33000# 1' in 1 minute.
Multiply that by 60 to get an hourly rate, and multiply again by the 50hp the tractor has and you get the total weight the tractor has the ability to lift 1ft in 1 hr.
Divide that by the tractors weight, and you get the vertical distance it can lift itself in 1 hr measured in ft. Multiply that by 2 for the 30 degree slope, and divide by 5280 to get miles per hour. And I get 8.5 is the speed it would maintain. And it would take 70hp for it to maintain the 12mph.
/ kubota vs. kioti #277
So, a "horsepower guy" says 8.5 mph. Anyone from the "torque camp" want to give their answer?
/ kubota vs. kioti #278
I get the same thing using the metric system. Converting the power of the tractor to 37,300 watts, it can move vertically at 1.9m/s. Multiply by 2 for distance, and by 2.24 for mph. 8.5 on the button.
/ kubota vs. kioti #279
In order for it to maintain top speed of 12, with its 50hp, it would have to be 20 degree grade or less. (36% grade)
2014 UTILITY 53X102 DRY VAN TRAILER (A59914)
2014 UTILITY...
New Landhonor LHR-COA200,  200lb Cast Iron Anvil (A62679)
New Landhonor...
2012 HINO 268 4X2 S/A BOX TRUCK (A59914)
2012 HINO 268 4X2...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
Case Axial-Flow Combine Wheels NO RESERVE (A63118)
Case Axial-Flow...
