Kubota vs Aftermarket
/ Kubota vs Aftermarket #1
john973
greensburg, pa
Kubota
Looking to purchase a new L3901 Kubota. I am getting front loader and backhoe, so I am trying to decide whether I should spend the extra $4500 to get Kubota brand or the dealer offers Ansung brand. I will be using around my house and 30 acre property for small projects. Is it worth the extra money?
Thanks for your help.
/ Kubota vs Aftermarket #2
If resale value is important, go with the Kubota stuff.
/ Kubota vs Aftermarket #4
What's the price difference? Do they have info to compare the capabilities of the two loaders?
Welcome to TBN.
/ Kubota vs Aftermarket #5
Here are my thoughts. The first Kubota dealer I worked for quit selling aftermarket loaders because they weren't worth the hassle. They had little problems that the manufacturer didn't want to warranty. You may also want to look at their warranty terms too. They may only be 6 months vs 2 years or whatever Kubota's tractor warranty is. I also recently learned that if it is non-Kubota equipment installed on your tractor (such as a loader or cab) Kubota does not cover their removal if they should need to come off for warranty repair on the machine. Some dealers will eat this cost some won't.
Brian
/ Kubota vs Aftermarket #6
Why not just buy a after market tractor?
/ Kubota vs Aftermarket #7
It looks funny with after-market stuff on it.
Also, welcome to TBN:welcome:
/ Kubota vs Aftermarket #8
Is it a subframe mounted kubota backhoe or a 3ph mounted backhoe?
I could see the difference in price if the Kubota was a subframe mount vs the other.
/ Kubota vs Aftermarket #9
I was under the impression that ansung was the OEM of backhoes for Kubota.
/ Kubota vs Aftermarket #10
I too have wondered about the ansung brand backhoe but have never seen any feedback. Let us know what you find out.
/ Kubota vs Aftermarket #11
Pretty sure Kubota makes their front loaders and backhoes in their Georgia facility, but I can't say if there's an Ansung connection.
/ Kubota vs Aftermarket #12
Let me guess a sub frame back hoe for a 3900 is $9500 right? With the aftermarket if it's not 3pt how would it fit the adapter plate of the Kubota sub frame? Too bad those hoes went up so much. If you happen to have a horse on the premises you can wrangle a 28% discount if you buy anything over $5,000 from Massey. I ended up with the 1736 Premium model you see on my postings for just around $29000. The hoe ended up IIRC last summer came in at around $7500 which about what they are really worth.
/ Kubota vs Aftermarket #14
I bought the Ansung 760 for my Branson 4020R. Used it about 20 hours so far with no problems. Tractor has an Ansung loader and the subframe for the backhoe overlaps and connects to the loader subframe and the lower three point arm conection point. You do have to remove the 3 point arms to attach the backhoe. Backhoe connects with 2 hooks at the rear and 2 hooks that take a pin at the front and 2 hoses. Pretty simple once it is lined up. Mine works just fine off tractor hydraulics at 1400 rpm.
Ansung web sight shows subrames for Kubota as well. The model numbers are specific for Kubota models.
EA has a video on them.
/ Kubota vs Aftermarket #15
Go for the Bota and never look back,you wont be sorry.:)
/ Kubota vs Aftermarket #16
The Build My Kubota thing lists the 7.7 ft costing about $7600 with subframe.
Can you really get the Ansung for $4500 less ($3100)?
/ Kubota vs Aftermarket #17
As a Kubota owner I would never even consider buying a new tractor with an aftermarket loader and hoe.... I want the entire unit covered under the same coverage and no bull crap of one vendor blaming the other.
Regards,
Chris
/ Kubota vs Aftermarket #18
I would not hesitate to go with Woods brand attachments, especially for the hoe. With the woods unit you can get a slightly stronger unit that has a separate PTO pump available.
Regards,
Chris
/ Kubota vs Aftermarket #19
Regards,
Chris
Its not quite that simple. The loader and BH will only have a 1 yr while the tractor will have 2yr but you do certainly eliminate the multi vendor crap
/ Kubota vs Aftermarket #20
It's the multi vendor stuff I hate.... Sure Woods or Wallenstien make good products ... Just don't like the finger pointing when a problem occurs.
Regards,
Chris
