Kubota Treadle Pedal...
   / Kubota Treadle Pedal... #1
5030
Epic Contributor
SE Michigan in the middle of nowhere
Kubota M9000 HDCC3 M9000 HDC
Out of curiosity I'm interested in owners opinions of the 'Treadle Pedal'.
I bought a used Kubota F series front mount diesel powered, hydrostat drive that has the Treadle Pedal and never having one or at least not for many years because the last hydrostat tractor I owned was a 5030 HSTC and I cannot remember if it had the Treadle Pedal or not actually and if it did, please tell me... Anyway, I'm very used to my big Kubota's with their gear drive, wet clutched drivelines so getting this has been an experience, an experience I don't particularly like actually.
Besides the loud whine the drive unit makes (and I believe that is normal for a hydrostat), I find the odd shaped pedal to be cumbersome. Going forward isn't an issue but backing up is. I have to remove my shoe from the pedal entirely and angle my shoe to the side and push on the lower part of the pedal to back up, something I find to be sort of tedious and if I don't keep the pedal bushing well greased (mine has a grease fitting on the linkage end), it wants to creep and unlike the hydro tractors, engaging the brake on the F Series entails pushing down on the brake pedal and then actuating a long rod to hold the brake on and the rod can only be accessed by bending over the steering wheel and grabbing it, a PITA.
Maybe I'm spoiled with the multi range wet clutched gear drive Kubota's I have but I find the Treadle Pedal to be less than ideal. Besides, it looks funky...lol
Read another thread that went into replacing that bearing and it didn't look easy at all. Least mine has no bearing as such, just a greaseable bushing that I keep greased.
Opinions welcome.
Other than that it's a great mower and eats up tall grass like a the hungry beast it is and it replaced a 60" zero turn mower. The F series with it's front mount mower is a joy to use, rides much better and having the mower out front, you can actually get under tree limbs and see what you are mowing and I really prefer the steering wheel over the 'oars' as well.
I had 8 years of 'Oars' and I won't go back. This one has a 72" deck as well. My ZTR had a 60" on it. Other than the PITA Treadle Pedal, I really like it and it just sips diesel unlike my ZTR with it's gas guzzling Kawasaki V twin that sucked down gas like a drunken sailor. 5 gallons of gas per mow versus maybe a gallon of ORD with this one and the diesel seems to have way more power too.
   / Kubota Treadle Pedal... #2
I hate just about every treadle peddle, with the exception of the one found in the Kubota Grand L (that one I like a lot and wouldn’t mind owning one). My foot doesn’t bend correctly and actually hurts to heal the reverse on most standard treadle peddles.
   / Kubota Treadle Pedal... #3
I have the treadle peddle on my L2501. I think it's great for work that is only a few hours. F is toe press and R is heel press with instant ability to control my speed to suit the terrain and the load.
For all day mowing, though, it gets tiring and I prefer a gear or shuttle shift.
   / Kubota Treadle Pedal... #4
Opinions welcome.
I thought you worked PT for a Kubota dealer and even did deliveries for them. You would think you would be used to all of this....
I have zero complaints with my treadle pedal. I didn't like it when I first got it after being used to the JD's dual pedals, but now it's second nature...
   / Kubota Treadle Pedal... #5
The Kubota treddles do require some getting used to. I have no experience with the F series, but the L and MX series look like this:
In both cases, my heel stays on the deck floor and I press down on the "wing" with the toe of my boot to go forward. For reverse, I slip my toe under the wing and lift. Forward to reverse is done with the twist of my ankle without lifting my foot. You can see the wear spots made by my heel.
Without seeing the treddle on the F, I don't know if this is possible though.
   / Kubota Treadle Pedal... #6
I only have experience with the Kubota BX treadle peddle. All my John Deeres have the side by side peddles which I find far superior.
That being said, I have found that if I keep my heal planted and just swing my toe under the forward peddle and pull up, it works pretty well. I never have to move my foot off the deck.
Dave
   / Kubota Treadle Pedal... #7
I hate my SIL's pedal on his Kubota. I much prefer the dual pedals on my JD.
   / Kubota Treadle Pedal... #8
I like my treadle pedal, quick action and I keep it greased once a month.
   / Kubota Treadle Pedal... #9
I have a treadle on my Cub Cadet ZTR and find it harder to use than the twin pedals on my John Deere 2520. I have been experimenting on different ways to use it and find that I can keep my toe on the forward pedal while rolling the side of my foot onto the back pedal, rather than lifting my foot off and moving it.
Incidentally, Kubota pedal placement was part of the reason I went with JD 17 years ago. Not the treadle issue, but the fact that (at least at that time and on the model I was considering) the brake pedal was on the same side as the direction pedal which I didn't and still don't like.
   / Kubota Treadle Pedal... #10
Wearing size 10 snow packs takes little more getting use to operating pedal.
2004 TRAVIS BODY & TRAILER DOUBLE ALUMINUM BELLY DUMP COMBO TRAILER (A58214)
2004 TRAVIS BODY &...
PALLET OF CHAINSAW PARTS (A58374)
PALLET OF CHAINSAW...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
2025 JMR 66in Single Cylinder Brush Grapple Skid Steer Attachment (A56857)
2025 JMR 66in...
