kubota tracks
/ kubota tracks #1
wheat
I know you have all heard this before, but I borrowed a small trackhoe kubota kx series and the track came off. I can't recxh the owner and I have a big job still to do, can anyone help. TW
/ kubota tracks #2
I don't know about the rubber track machines, but usually it requires that a pin be removed and the track put back on the sprocket and pulley. Some machines use grease that is pumped into the track area to put pressure on the track and keep it on. The more important question is not how to put it back on, but why it came off in the first place. Under some strenuous situations, it is possible to throw a track, but this is rare on a well maintained machine. My old Oliver would occasionally throw a track but that was a result of the sprocket being worn and the track needing new bushings and pins.. Sorry I can't help you any more than this, but TBN is primarily for wheeled tractors, not track machines.....
/ kubota tracks
Thank you very much for your response, the track, sproket and front roller seem to be in good condition, but the adjustment may hhave been off. I fiqured I could adjust it if I knew how to put it back on. I was backing up a very steep mountain while digging an electric line trench and just heard a loud pop, then noticed the track had come off. Thanks again for the info, I'll try again in the am to seek the solution. Tim
/ kubota tracks #4
Tim most of the the Kubota excavators use grease to push the front roller out to keep tension on the tracks.
First jack it up just enough to get the track to slide back on. If you jack it up to high you will just fight gravity, as it will want to sag in the middle.
There should be a cover about 1.5"x3" on the side of the undercarriage and behind that you will find a grease fitting. You need to remove the grease fitting to relieve the pressure. Then push the front roller in, which will push out more grease and should give you enough room to get the track back on.
Once it is back on, install grease fitting and pump it up until you have proper track tension.
J.D.
/ kubota tracks
Thank you so much, I'll try it and give it a shot, no pun intended. TW
/ kubota tracks
J.D.,
You are the man, it worked and so did I all day with a great machine. Thanks again, You saved me. TW
/ kubota tracks #7
Hmmm: this is probably unrelated, but. We had a guy come out with a "Daedong" track hoe (Is that what you call them: a bubble of cast iron with a backhoe stuck on it?) to move some dirt and manure and pull a few stumps. He left behind three 8"-long pieces of steel with bits of rubber stuck to them in the dirt. My wife showed him one and said," Is this part of your machine?" He said that he hoped not and kept digging. Every so often we heard a little clanging sound from down low on his machine. I think this man was in some kind of denial. (But then his tracks DID stay on.)
/ kubota tracks #8
<font color="blue"> J.D.,
You are the man... </font>
Could not help but think....and TBN is the site!!!!! /forums/images/graemlins/smile.gif
Glad all became well and that JD is da man... /forums/images/graemlins/grin.gif
CHANDLER 14' LITTER SPREADER (A64277)
CHANDLER 14'...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
John Deere 757 Zero Turn Mower (A66285)
John Deere 757...
Willmar 4550 Wrangler Articulating Loader (A63689)
Willmar 4550...
Hayrack Wagon (A66408)
