Kubota Trac Vac
   / Kubota Trac Vac #12
Can you just offset the trailer to one side useing a drawbar between the lift arms.
   / Kubota Trac Vac
I notice that a couple of posts have asked if just shortening the drawbar would help. I only have one more adjustment left to shorten it and I will try that but again I'm probably going to get into the 3 point arms when I do that. By far it looks like I need to put a piece of 8" stove pipe in the hose to lengthen it and run it up over the tire attaching a bracket to the rops. I have changed my mind however about a rigid ring to run the hose through. It was pointed out to me that I will need some flex in the hose to allow for turning so I'm going to rig up a removeable bracket that I can use a bungee cord on to hang the hose from. It will just be a small eyelet or ring welded onto some flat stock that will bolt on the rops and can be removed quickly. I'll post a couple of photos after I get it done. Thanks to all that replied. A great thing about owning a CUT is if you get into a jam and need help its only a trip to the computer away.
Hagman
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
UNUSED 30PCS Brown Metal Roof Panels (A53117)
UNUSED 30PCS Brown...
2004 CATERPILLAR CS-563E SMOOTH DRUM ROLLER (A52707)
2004 CATERPILLAR...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2025 JMR Tree Boom Skid Steer Attachment (A53421)
2025 JMR Tree Boom...
401 (A52706)
401 (A52706)
