Kubota Trac Vac
   / Kubota Trac Vac #12
Can you just offset the trailer to one side useing a drawbar between the lift arms.
   / Kubota Trac Vac
I notice that a couple of posts have asked if just shortening the drawbar would help. I only have one more adjustment left to shorten it and I will try that but again I'm probably going to get into the 3 point arms when I do that. By far it looks like I need to put a piece of 8" stove pipe in the hose to lengthen it and run it up over the tire attaching a bracket to the rops. I have changed my mind however about a rigid ring to run the hose through. It was pointed out to me that I will need some flex in the hose to allow for turning so I'm going to rig up a removeable bracket that I can use a bungee cord on to hang the hose from. It will just be a small eyelet or ring welded onto some flat stock that will bolt on the rops and can be removed quickly. I'll post a couple of photos after I get it done. Thanks to all that replied. A great thing about owning a CUT is if you get into a jam and need help its only a trip to the computer away.
Hagman
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
UNUSED IRANCH 14' BI-PARTING GATE (DAMAGED) (A57193)
UNUSED IRANCH 14'...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A57192)
UNUSED SET OF...
2014 Ford Explorer Limited SUV (A55853)
2014 Ford Explorer...
UNUSED PAIR OF MINI RUBBER TRACKS (A57193)
UNUSED PAIR OF...
