Kubota Top N Tilt Kit
   / Kubota Top N Tilt Kit #31
Re: Probably a stupid question, but.....
Ah so.
Winnipeg, Manitoba, Canada
2001 BX2200
All Kubota FEL,
Tiller, box blade,
blower w/elec shute,
60 mid mt deck.
Ag tires on order.
Traded up from a 1984 JD 318 after 687 hrs.
No such thing as a stupid question as far as I'm concerned, woodstock. Thanks to all for the posts. Valuable info to me. Thanks to Ron for detailing his project. I have not gotten any response from the e-mail inquiries to Gearmore and Gannon. Kind of bugs me that some manufacturers post an e-mail "get in touch with us" address, then don't ever check their mail or just ignore it.
It's certainly not like I have money burning a hole in my pocket, but it's kind of strange that I'm ready to buy and can't find anybody to deliver the goods. Just goes to show you what a unique (surely not strange) bunch of consumers we TBNer's are, I guess.
   / Kubota Top N Tilt Kit #33
<font color=blue>Couldn't I rob this cylinder and use it on the top of the 3-pt to give me the tilting feature everyone is drooling about</font color=blue>
What kind of ends does that cylinder have on it? Are they the same as the ends on your existing top link? And is that cylinder the right length? In other words, it might be possible, but I'm no help because I know absolutely nothing about snow blowers./w3tcompact/icons/crazy.gif Hey, that ain't quite true; I learned on TBN that you can get 'em to go on either end of your tractor; front or rear./w3tcompact/icons/wink.gif
Bird
   / Kubota Top N Tilt Kit #34
<font color=blue>I periodically turn around and "pick up" detritus with the FEL.</font color=blue>
"detritus" -- Wow, GlueGuy! I thought GlennMac was the only one with a dictionary flowing through his veins! /w3tcompact/icons/smile.gif
If I keep reading this board, I may eventually be inculcated with sufficient vocabulary to constitute a lexis of my own. /w3tcompact/icons/wink.gif
   / Kubota Top N Tilt Kit #35
Woodstock
The top link cylinder has a ball on both ends similar to your adjustable top link. The cylinder for snow blower will not have the ball ends. The cylinder that is used to raise snow blower may be too large in diameter to clear lift arms and fittings. On my old Farmal I made an adapter that screwed onto cylinder rod that had ball end welded to it. You may want to add a valve to operate the top link cylinder so the FEL can still be used.
   / Kubota Top N Tilt Kit #36
GlueGuy
I read your message and just went over the word Detritus figuring you meant Debris. But after reading Harv's response I had to go to Webster's Dictionary to find out if I was right. What an education./w3tcompact/icons/smile.gif Not only do I learn about tractors. But also the English that I did not learn as well as I should have 50 years ago.
Main Entry: de·tri·tus
Pronunciation: di-'trI-t&s
Function: noun
Inflected Form(s): plural de·tri·tus /-'trI-t&s, -'trI-"tüs/
Etymology: French détritus, from Latin detritus, past participle of deterere
Date: 1802
1 : loose material (as rock fragments or organic particles) that results directly from disintegration
2 : a product of disintegration, destruction, or wearing away : DEBRIS
- de·tri·tal /-'trI-t&l/ adjective
Thanks /w3tcompact/icons/cool.gif
   / Kubota Top N Tilt Kit #38
OK, I will remove all doubt by asking a definitively stupid question ... what the heck is "Top N Tilt" and what would it do for me (other than cost me more money)?
Don
Don,
Basically, it is replacing the manually screw-adjustable top link (top) and one of the lift links (tilt) with a hydraulic cylinders and, control valves. Saves you getiing off the tractor for making the adjustments. It's not such a big deal unless you use "landscape" 3pt equipment frequently. It's especially nice with a box blade since small adjustments in the top link make a big difference in performance. If you are not doing work for hire, yes, I would call it a bit of a luxury...but, for many of us, aren't tractors in the first place?
   / Kubota Top N Tilt Kit #40
Bill: just wanted u to know that my tractor is not a luxury! i absolutly need it to hmm? (wait i am thinking) hum? i know!! i need to move a lot of "detritus". /w3tcompact/icons/wink.gif boy u guys keep me thinking all the time.
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
2019 Kohler 50REOZK 50 kW Diesel Generator (A56857)
2019 Kohler...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2013 MACK CHU613 (A58214)
2013 MACK CHU613...
500 Gallon Poly Tank (A59076)
500 Gallon Poly...
2006 Intellistrobe Automatic Flagger Assistance Device S/A Towabale Trailer (A55973)
2006 Intellistrobe...
