Kubota squeaky AC compressor
/ Kubota squeaky AC compressor #1
Komrade
Western Morgan County, WV
Kubota L3430 HST
Initially thought it was belt and tightened it, but it didn't help.
Sounds like clutch is not catching.
Any pointers to fix and diagnose it myself much appreciated.
Does not squeak with AC off
/ Kubota squeaky AC compressor #2
Check the voltage to the clutch when it's turned on and supposedly operating. If it's less than 12 volts then try "jumping" battery power to the clutch and see if it still slips when running under load. Could be a bad clutch (even a bad compressor or system charge I guess) or could be it's just not getting full voltage.
/ Kubota squeaky AC compressor #3
They do wear out, that is the friction plate(s) get too thin and won't securely lock up. Some are adjustable, most aren't so replace it. Just don't buy it OEM, Get aftermarket, much cheaper and compressor clutches aren't rocket science.
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
2020 GMC AT4 CREW CAB TRUCK (A65054)
2020 GMC AT4 CREW...
2008 Ford Expedition SUV (A61574)
2008 Ford...
EZ Trail 3400 (A63688)
Landhonor Quick Attach Seeder (A66285)
Landhonor Quick...
