Kubota safety circuit description-post yours.
/ Kubota safety circuit description-post yours. #1
EE_Bota
Elite Member
North Carolina
Kubota BX2200
For the BX2200:
Current from the Battery + terminal goes to the + terminal of the starter solenoid. Also connected to that terminal is a 12 Red wire. It goes:
1)through 30 amp slow blow fuse. Then splits.
2)the path we are interested in is to Terminal 30 of the ignition switch.
3)in start position..out terminal 50 of the ignition switch through 14 Black/white striped wire to first one then the other safety switch (which is first it does not say.)
5)to other terminal of starter circuit. This completes the circuit because the solenoid is grounded through it's mount, so both terminals on the solenoid are positive..one was from the battery, and the other is from the start position of the ignition switch.
My manual does not show a seat safety switch.
/ Kubota safety circuit description-post yours. #2
If you could show a picture or a scan of your workshop manual it would be easier to understand.
yea, I know KubotaSam...I don't have a scanner right now. I am thinking of getting one on order from Tiger. If/when it arrives, I will revise.
Thanks.
