Kubota rtvx1130
   / Kubota rtvx1130 #21
For those of you with the diesel Kubota rtv: When you're out with it and let's say you're driving 100 yards here, 50 yards there, 400 yards there, on and on with maybe 3-5 minute stops after each short drive, do you shut the engine off at each 3-5 minute stop? Im talking about mid-temperature day, not trying to keep the cab cold or hot, engine is warmed up..
It's mixed for me. I do both, and don't think it matters much either way.
   / Kubota rtvx1130 #22
Me, too. I only stopped leaving it running to save the hour meter, LOL. I used to never shut it off, thinking that constant starts and stops would wear the starter out. However, in hot summers like the one we just had, it sure was nice to get back into a cold cab!
   / Kubota rtvx1130 #23
Yeah, same - mixed - under 5 minutes, leave it running. Otherwise, shut it down. I will admit I've replaced one starter...in 14 years and 2400 hours... But, a remarkably trouble free machine with good maintenance.
   / Kubota rtvx1130 #24
I think that's a pretty good track record if you ask me. :)
   / Kubota rtvx1130 #25
have any 1130 owners installed a hand throttle on your machine?
   / Kubota rtvx1130 #26
I considered it because a number of people suggested it would improve performance. But the same thing can be accomplished by making sure the throttle & HST linkages are adjusted correctly, and backing off the HST if you are lugging down the engine RPMs. So I never installed one.
   / Kubota rtvx1130 #27
I prefer the foot pedal
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
24in pin on excavator tooth bucket (A61306)
24in pin on...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2016 VOLVO SD75B SMOOTH DRUM ROLLER (A60429)
2016 VOLVO SD75B...
2025 40ft 10-Door Shipping Container (A59228)
2025 40ft 10-Door...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
