Kubota rotoriller seal leaking
/ Kubota rotoriller seal leaking #1
ponar
Port Alberni
Kubota B6000
I own an older Kubota B6000 with a pto driven rototiller. Unfortunately I cannot find any model number for the tiller. I have an oil leak on one side of the tiller where the shaft goes into the main housing. Have pictures that I can send. Has anyone else had the same problem and where the heck can you get replacement parts???
/ Kubota rotoriller seal leaking #2
Most bearing supply companies can match up both bearings and seals. Such items are not normally not made specific for the equipment manufacturers. Over the years I have matched up (sometimes exact and others close enough) many seals and bearings. Check your bearing and shaft for wear. Seals fail for many reasons except obvious old age.
Once a manufacturer like Kubota puts their part # on a generic item the price can double.
Ron
Ron
Thanks Ron.
Still trying to identify the rototiller. I do have some pictures of it plus I just found some numbers on the tiller tines. Please send me an email to pmurray1949@yahoo.ca and I will forwad th info to you. Maybe you can identify it.
Peter
/ Kubota rotoriller seal leaking #4
As Ron already mentioned. Bearing supply house can match it up once you have it out. Many times much cheaper also.
I had a Dodge that the dealership wanted 90 bucks for a bearing. Bearing supply charged me a whopping $14.00 for it.
Post a photo of it on this thread. I'm sure someone could ID the tiller for you
Regard's
Sean
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
2025 Vicsec 30in. Bucket Mini Excavator Attachment (A64553)
2025 Vicsec 30in...
2019 Chevrolet Tahoe SUV (A64557)
2019 Chevrolet...
2013 CHEVROLET 2500 HD (INOPERABLE) (A65643)
2013 CHEVROLET...
