Kubota Remotes Question
/ Kubota Remotes Question #1
mcd176
Wheeling, WV
Kubota M6800HD / Kubota B2150
What size male couplers work on Kubotas rear remotes, I tried using the ones from my NH and they dont work, Are Kubota couplers only available from my dealer?
/ Kubota Remotes Question #2
Mike
You can get couplers from TSC or any farm supply store. You will want pioneer couplers with the ball on the end, not with the pin If you do not understand what I am referring to I will look for the part number for you, KennyV.
/ Kubota Remotes Question #3
My Kubota remores--and almost every modern remote--is a standard size. If you are new at this, make sure the cylinders are not under "load" and try harder before anything else.
/ Kubota Remotes Question #4
there are different sizes of pioneer couplers, and if you had a smaller tractor before you may well need to size up
Thanks to everyone, I had a dumb *** attack, the couplers from my NH TC35 work just fine on my Kubota. :D
/ Kubota Remotes Question #6
mcd176 said:
Thanks to everyone, I had a dumb *** attack. . . :D
That seems to be a common ailment. We've all been afflicted with it at one time or another!;)
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
LOT OF TRANSPLANTER PARTS (A64278)
LOT OF...
Mack T/A Day Cab Truck Tractor (A64556)
Mack T/A Day Cab...
KMC 18' FIELD CULTIVATOR (A64278)
KMC 18' FIELD...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
