Kubota rear remotes
/ Kubota rear remotes
Thanks Mad, and everyone!
I think I've got it now.....
/ Kubota rear remotes #22
kennyd said:
You would not want to put a valve rated lower than the maximum GPM of the tractor, because this is a "open center" system. The new valve needs to be able to flow the oil without restriction.
Say you put a valve that was rated at 5GPM on a machine that's pump was rated at 10GPM, you could have a restriction in the hydraulic circuit the could cause overheating.
Question on this; is the GPM rating of a valve related to the supply through the spool to the work ports or from the supply through the OC to the power beyond or both? I was always under the impression it was related to the work ports for a couple of reasons; the work ports are usually quite a bit smaller and half of applications are closed center systems where GPM 'through' the valve would be meaningless.
/ Kubota rear remotes #23
Both. However, I don't quite understand your comment that "half of applications are closed center systems". Just about every tractor and piece of heavy equipment that I know of has open center hydraulic systems.
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
(7) KUBOTA BRUSH GUARDS (A64280)
(7) KUBOTA BRUSH...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
211299 (A62131)
211299 (A62131)
2008 Bush Hog 3715 15ft. Batwing Rotary Brush Cutter Tractor Attachment (A61572)
2008 Bush Hog 3715...
Transfer tank (A61567)
