Kubota Rear Light
/ Kubota Rear Light #1
nitroxn
Maryville, Tennessee
Kubota B7510DT
Rear light with switch and quick disconnect. Chose quick disconnect to be able to other 12 volt acc.
/ Kubota Rear Light #2
I don't know anything about wiring, but I'd love to have a rear light like yours. Could you go into a bit more detail on how you did it? I have a 2003 B7500 so it should be similar.
Thanks,
Steve
/ Kubota Rear Light #3
It kind of looks flimsy hanging out there like that, but I like it. Nice job! If your driving that close to stuff you have other things to worry about. I like your setup more than some of the others I've seen on ROPS or similar positions PLUS you can lean a rake or shovel against it to boot!
Do you have one on either side? Where did you get the lights? Are they flood or spot? A little more info would be nice, but cool pic.
Oops, just noticed you have it mounted to the inside (hence the edit), I really like it now, but you lost your place to lean stuff without sliding. /forums/images/graemlins/tongue.gif
/ Kubota Rear Light
It is a PIAA fog light with a spot beam. The wiring for whatever was already there, I just tapped into the wiring and ran it thru the switch. Thru the switch and into a male/female quick disconnect so that the switch can be used to turn other things on and off. ie sprayer. The light I mounted on a 1 1/2 x 1/8 aluminum flat bar. The flat bar I drilled a hole the same size as the mount on the signal/hazard light But I put a large diameter plastic washer between the flat bar and the paint on the tractor. I forget where I got the light but it is cast aluminum and I only got one of them. I think it was a warranty at my old job.
/ Kubota Rear Light
Another picture.
