Kubota range shifter sticks
/ Kubota range shifter sticks #1
127wsr
Waveland, MS
Kubota 3000
I need help with a Kubota 3000 DT range shifter that is difficult to shift. The tractor has less than 400 hours but is 12 years old. Any suggestions will be appreciated
/ Kubota range shifter sticks #3
go to the Kabota forum and ask there, I'm sure someone there can help!
:welcome: to TBN! :thumbsup:
Happy :tractor: ing!
/ Kubota range shifter sticks #5
I have a L4400 and the range shifter has to have the tractor unloaded to shift. I sometimes have to rock the HST pedal back or forth a bit to get the gears to unmesh. Try to put it in gear and put just a little pressure on the range select. Then let the clutch out a little till you start to move and push it in quick(keeping a little pressure on the range shifter) that usually gives a little slack in the gears so they can unmesh.
Thanks for the comments on my Kubota 3000 DT range shifter that sticks. I should have been more specific in the first post. The tractor has a manual gear box.
/ Kubota range shifter sticks #7
is your gear shifter in neutral when you try to select either H or L range? being in neutral seems to help on my manual tranny. also, assume your hyd fluid is in good shape & up to level. could any linkages be loose?
/ Kubota range shifter sticks #8
The H-L shift on my L3830 can be ornery at times. Eventually, it will shift when the tractor is in neutral using plenty of Jack Armstrong. Occasionally, I have to rock the tractor back and forth. I have made shifting between H-L a part of my daily routine, even though I rarely use the tractor in the H range.
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
2022 BOBCAT T870 SKID STEER (A64279)
2022 BOBCAT T870...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
2022 John Deere 7R 210 Tractor (A63111)
2022 John Deere 7R...
Excavator trenching bucket- one bucket per lot (A63689)
Excavator...
