Snow Kubota Quick Hitch
/ Kubota Quick Hitch #1
carpec53
UPSTATE NEW YORK
KUBOTA B3030
Hi everyone. I just bought a used B2782 front mount mount snowblower for my '08 B3030. It was mounted on a B2910. Can anyone tell me if the Quick Hitch for a B2910 (I think it's a model B2761) is compatible with the B3030. They seem to be about the same size (bolt spacing, etc) but I wondered if anyone else had a similar experience. For the price ($2200) and in excellent shape I didn't think I could go wrong. Thanks.
/ Kubota Quick Hitch #2
I have a 2007 B3030HSDC and the B2782 front blower.It uses the B2791 Quick Hitch and Subframe for models B2630,B2710,B2910,B3030,and B7800 tractors.The manual part number is 70060-02812.Sounds like this will fit your unit.The instructions vary by model,so you may wish to purchase the manual to correctly install for your application.B2782 blower manual is part number 70060-02773.Sounds like a deal! Good Luck.
/ Kubota Quick Hitch #3
I've been dealing with the same question--the compatibility of my B2782 blower with my new (used) B3030. I have a 2003 B2710 with B2782 blower and B2761 subframe and quick hitch. I recently bought a 2005 B3030 but the dealer could not tell me whether my 2782 blower would work on the subframe and quick hitch for the B3030. My 2761 subframe will not fit on the B3030 because the width of the two tractor frames is not the same. But if I'm understanding what Number Two is saying, it sounds like the quick hitch may be compatible between the two tractors but not the subframe. Since the B2710 and 2910 have the same frame, it seems like this is the answer for New Member: He and I both need to purchase the subframe/quick attach for our 3030's. Does this sound right?
/ Kubota Quick Hitch #4
Though it might work, (I don't know for sure) the quick hitch for the B3030/B3200/B2630 is different from the one used on the B7800, and mounts to the tractor at different points. I've saved some pictures other members have uploaded, so let me see if I can find some...... Yes, you will see that the newer quick hitch is much shorter.
/ Kubota Quick Hitch #5
Thank you Chuck(wishing you good health) for the excellent observation and pictures.My guess is that the B2791 quick hitch/subframe is the more recent version of the quick hitch/subframe,since my manual has instructions for all of the previously mentioned tractors.Another thought is the mid PTO kit is B2793(the blower driveshaft)on my unit may be different.I'll look forward to more posts here on this subject.
/ Kubota Quick Hitch #6
I realize this is a very old thread, but have a similar desire to seek what is compatible with a B3030 Cab tractor.
Recently I purchased a B3030 Cab tractor for my Dad to make life a bit more comfortable as he becomes more sensitive to inclement weather. As such I'm actively seeking a used front snowblower as I can't afford to buy new. To help in the search I need to know what is compatible.
From the current Wholegoods price list I've determined the following:
Snowblower: B2782
Quickhitch/subframe: B2791
Mid PTO Driveline Kit Cab: B2793
B2791 is compatible with the following tractors B2630, B3030, B2710, B2910, B7800, B3200, B3000.
I've found a number of snowblowers from B2710/B2910 and other tractors using subframe B2761. Since B2791 seems to be backward compatible, is B2761 forward compatible to the B3030?
Has anyone used a B2761 on a B3030 with success?
I'm aware a different drivetrain is needed between a B3030 and B3030 Cab.
Does anyone want to sell me a front snowblower for a B3030?
Does anyone have a copy of the Wholegoods price list from 2004-2011 that might cover B2761?
Thanks in advance for your help.
/ Kubota Quick Hitch #7
Hi moship! Got your PM.
I suspect Chuck's pdf showing the rearward mounted quick-hitch subframe may be the B2761.
If that is the case,it most likely was never designed for the B3030.
Last week,project x posted the pdf for theB2791 -this may help!
And when buying a used kit,the not needed parts you may need for a different model will have been discarded.
Good Luck and post back with your results.
/ Kubota Quick Hitch #8
Thanks for the posts and I'll investigate the details of each.
What blower and quick hitch do you have on your B3030?
Do you or anyone have any leads on a snowblower?
I know it will be very difficult to find a complete setup (1.Snowblower, 2.Quick Hitch, 3.Driveline Kit and 4.Hydraulic Chute Rotation) for a B3030 Cab and will likely need to buy something that has 2 or 3 of the major items and purchasing the balance new.
Thanks again for your help and welcome any info that may help my quest to buy a used front snowblower.
/ Kubota Quick Hitch #9
moship-We have the B2782 blower,now I think it is now a B2782A-not sure what,if any difference there is.
B2791 quick hitch/subframe.
B2793 mid PTO kit.
Plus the hydraulic chute rotator all new 10 years ago for $4500 US at the time.
This season,I added the B2786 side extensions,an idea I got from member sandyc.
Hope this helps and good luck with your search!
Jim
/ Kubota Quick Hitch #10
Thanks Number Two for the details.
I'm actively searching and would like to find something exactly as you have sooner than later.
1998 INTERNATIONAL 9100 DAY CAB ROAD TRACTOR (A63291)
1998 INTERNATIONAL...
96" X 20' TRI-AXLE TRAILER (A64280)
96" X 20' TRI-AXLE...
12' CHISEL PLOW, 3PT (A63291)
12' CHISEL PLOW...
1995 CUSHMAN TURF HAULER (A64280)
1995 CUSHMAN TURF...
UNUSED IREV HIGH-END 2 WHEEL ELECTRIC VEHICLE (A64281)
UNUSED IREV...
UNUSED WOLVERINE MCB-11-48W 48" HYD 4N1 BUCKET (A64281)
UNUSED WOLVERINE...
