Kubota Quick Coupler
/ Kubota Quick Coupler #1
roaf3x
Hi Guys,
Can anyone comment on the quality of the Kubota brand quick coupler.
There are no aftermarket (horst ATI) yat as the loader LA 524 on L3200 is
pretty new. I know the old ones did not fit well and popped off.
Do they fit standard skid steer plates well or are they sloppy.
Refabbing a new tractor is something I would like to avoid.
Thoughts ? Pictures? or Comments are all appreciated!
Cheers,
RD
/ Kubota Quick Coupler #2
I have a Kubota QA on my FEL and it fits very well. I bought some blank plates to fab up a few attachments and they fit nice as well.
/ Kubota Quick Coupler #3
The quick attach on my tractor works great and it is the skid steer type. Besides the Kubota bucket it works without issue on a inexpensive pallet fork attachment I have.
After experiencing the QA first hand, I would recommend anyone buying a FEL to consider the QA a manditory option even if you do not have an immediate need.
/ Kubota Quick Coupler #5
That is some of the best advice I've seen here on TBN.
Thanks guys.
I was concerned the Kubota portion of the coupler was weak and non standard.
It seems that they have improved are are pretty strong.
Thanks!
RD
/ Kubota Quick Coupler #11
And the very first bunch on the LA853 or what ever came on the L30 series. There is a 10$ shim and spring kit to fix it.
The only coupler Kubota ever had fit problems with was the one on the L48, other than that they've been flawless.
/ Kubota Quick Coupler #12
Aaargh! You are absolutely right. The Jari USA products are designed for the BX Series. Time for another cup of coffee - maybe that will sharpen my reading skills a bit!
Thanks for the replies. I have an ATI bucket that I just welded a Bradco adapter to the bucket.
I wanted to make sure that the Kubota attach would work and was beefy
enough to work especially when back dragging.
It sounds good.
Many Thanks !
RD
John Deere 1023E (A62177)
John Deere 1023E...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2021 TAKEUCHI TB240 EXCAVATOR (A64279)
2021 TAKEUCHI...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
