Kubota Paint and Primer
/ Kubota Paint and Primer #21
Some very good advice here. In my experience, Rustoleum is very good paint - as long as you let it cure for a month or so before heavy use. Most of the complaints about Rustoleum stem from not letting it fully cure.
Isocyanate paints are incredible, although orange peel can be a challenge for limited experience painters like me. I have a fresh air breathing system and would never spray an iso paint without it.
/ Kubota Paint and Primer #22
Any one try the TSC Magic kubota orange paint? I got a gallon to try on both of my pieces of equipment. I have usualy sprayed rustoleum oil based through my purple HF hvlp gun and wanted to try a different brand.
Im looking more for a preservation finish rather than a show room quality. How ever i have sprayed a few metal cabinets that came out very nice.
/ Kubota Paint and Primer #23
The Majic enamel IS NOT Orange 2, it's close to Orange 1, so if your Kubby is late model, it won't match.
/ Kubota Paint and Primer #24
Another thing about hardeners--isocyanates--is the damage they can do to your lungs. Read the darned can. ONE use can permanently damage your lungs and you must wear a supplied air (spacesuit) system with air drawn from outside the building. The damage doesn't have to show up right away and may never show up but the risk is considerable.
The fact is, there are about a hundred toxic cancer causing chemicals in the paint, with or without the isocyanate hardener in it.
And, the proper level of personal protection when using these products is exactly the same whether you add the hardener or not.
There are not a lot of guidelines for how to use a charcoal respirator safely. This is because only exposure testing can determine your exact level of need.
Having been through the required exposure testing, I can tell you that I was cleared to use a 3M disposable respirator in excess of 40 hours of spraying. So, if you put it in a sealed container when not using it, even under the worst conditions you will never have a problem getting 20 hours of use out of one, spraying this type of material.
If after using it, it acquires an odor that can only be described as the smell of stale beer, you have to replace it. This can happen if it has been used, and sits in storage for a long period of time. or, gets left out in the open air.
/ Kubota Paint and Primer #26
Isocyanates are diferent from just plain paint and incredibly dangerous. Paint respirators are not sufficient to safeguard the user.
CDC - Isocyanates - NIOSH Workplace Safety and Health Topic
Isocyanates and Asthma < Painters and Repairers Education Program
I don't need an education on this, I have been using these products professionally for over 40 years.
Yes, isocyanates are dangerous. However, only a very small percentage of people are ever affected by them. The vast majority of people who use them in this country daily, DO NOT take the proper precautions, (trust me, I have seen it first hand, by others using them professionally). After many decades, there is no epidemic. Yes, some people do get sick. But, it's not a widespread problem. If there was, the lawyers would be all over it.
Realistically, you can't even take the lid off the can of hardener, or walk in to the area paint is being mixed, or painted parts are drying or resting, without being exposed to the isocyanates, as well as all the other chemicals in there. Yet, you can go in to any shop, or watch any video on using these products, and see people doing these tasks without any respiratory protection. They are all breathing this stuff in every day.
I believe in using the proper protection. And, though you seem to want to believe that the other ingredients are not as dangerous, THEY ARE. And, to some people they may be more dangerous. Many paint chemicals are known carcinogens. You can't know which chemical(s) are going to do you in. So, if you are smart, you protect yourself from ALL of them.
It is incorrect to say paint respirators are insufficient. They are made exactly for this purpose, and used properly, along with the correct other personal protective equipment, will protect you.
The ONLY problem with using a respirator here is, without testing, you can't know your exposure level. So, you can't know how long you can wear it before you have to replace the filters.
I have had many OSHA certification classes, and been OSHA exposure tested for isocyantes, as well as all the other chemicals in the paint. This DOES allow you to use a paint respirator for protection. Because, you can calculate the amount of exposure in PPM, per hour, and divide by the amount of PPM the respirator can trap. Using this formula, you can CONCLUSIVELY show that your employee is protected, that MEETS the OSHA requirements.
Spraying all day long, my exposure levels were well within what my respirator could protect me from for over 40 hours of use. And, you are never going to find yourselves using these products at the level I was, when the testing was done.
So, as I said, if you really want to overkill it, don't go past 20 hours of use, on a set of filters and you will be fine.
Fresh air systems can give you false security. Have you tested the air quality? If not, you have no idea what you are breathing. There could be among others, oil, and toxic chemicals that have been drawn into the pump, or is leeching out of the hoses. These systems also usually have filters that also need to be exposure tested to determine the change interval. Otherwise, they could eventually be putting contaminates into the air instead of taking them out.
I have used several types of respiratory protection. I do not like air supplied systems primarily because I do not like having a hose tugging on my belt. It gets hung up on things all the time when you are moving around. There is enough to worry about when you are doing this work, without adding to the list.
/ Kubota Paint and Primer #27
I think your post would be commonly defined as .....using logic!
Thank you!
/ Kubota Paint and Primer #28
Thank you. All my kubota stuff is 1990 vintage so even if it would "match" im sure years out in the sun would change the color anyway.
/ Kubota Paint and Primer #29
Pretty much SOP with all Kubota's. They go from orange to Mary Kay pink...:D
But then so does JD. JD's go from JD green to Lima bean green.
/ Kubota Paint and Primer #30
Interestingly, I have a can of the Majic hardener on the shelf, unopened and I looked at the label this morning and nowhere does it state it's an isocynate (sic). All it states is how much to add to a certain volume of paint. Never used the stuff and candidly, don't plan to.
/ Kubota Paint and Primer #31
According to the Material Safety Data Sheet, (MSDS), It's 58% isocyanate by weight.
When they pack the cans, they fill the airspace with nitrogen. So, an unopened can will keep much longer than it does once you open it.
Hardners are notorious for hardening in the can, after they have been opened.
If you ever want to use it again after opening, thoroughly clean the threads on the can, and the cap with solvent. Even a little hardener on there will very effectively glue the lid on can.
I also wrap all supplies to be put in storage with a layer of aluminum foil tape at the can openings. I have found this greatly extends their "after opening" shelf life.
/ Kubota Paint and Primer #32
I don't use hardener but the way I keep partially filled cans of paint from drying out is simply to store them upside down. Then air can't get in to dry them out.
When I open a can I punch some holes around the rim to let paint drain back after being poured out. When done, I wipe the rim, put the lid on and store upside down. I used a half can of Kubota Orange II recently that I had opened last summer and it poured like fresh paint. I paint a lot and have been doing this for years. Works great.
/ Kubota Paint and Primer #33
Good tip. I 'hate' it when you open a partial can and it's skinned over and you have to fish the skin out. Thanks, I'll do just that.
/ Kubota Paint and Primer #34
When you do this, don't you get drying on the bottom (temporary top?). You have the same amount of air either way.
/ Kubota Paint and Primer #36
Nope, no skin. I figure it's not just the air already in the can but the extra air that seeps in and out when stored upright. Looks just like a partial can of paint when I turn over and open it up. I do shake it hard first but if there was any skin I would see it and do not. I've done maybe 25 cans like this over the years and never a problem.
/ Kubota Paint and Primer #37
I have been doing the same for more than 40 years
It works!
/ Kubota Paint and Primer #38
It works!
Just went out and inverted all my partial cans. It might not help at this point, but it won't hurt either. From now on, upside down like upside down cake...:D
70 years old and learned something new today. Life is good. Thanks.
/ Kubota Paint and Primer #39
Here's the icing on the cake because upside down storage also works with many of your wife's spices. Turn them upside down in the cupboard and they stay fresher, longer. The fluffy ones not so much but the denser and finer granulated or ground ones yes indeed. Wife won't let me try it yet but I'll bet it works with honey and real maple syrup as well.
/ Kubota Paint and Primer #40
Be careful!
Over the years, I have several times had a can top that was not on as firmly as I thought.
A week, a month, or more, later.....BIG ugly surprise.
2008 DRAGON PNEUMATIC TRAILER (A58214)
2008 DRAGON...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
1994 Fontaine 45ft. 40 Ton T/A Flatbed Trailer (A59230)
1994 Fontaine...
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
