kubota overheat problem
/ kubota overheat problem #1
ancientoaks
have a 1995 2950...bought three years ago w/312 hours..babied...bushhogged the first year no problem..secondyear was getting hot after about 2 hrs...this summer, coolest on record, gets HOT, redlined if you let it, after just 45 mn. or so...have cleaned screen, radiator..replaced thermostat...don't understand..tractor will run all day as long as no load is applied..then wham..heats up..dropping gear and running slower thru the weeds helps just a fraction, but still will get hot...at this rate it will take 3 wk to mow 30 acres...any help it appreciated...also have two buddies have same tractor and now are expeirencing the same problem...what's going on here?????
/ kubota overheat problem #2
The radiator is dirty in between the fins. The radiator can look clean and still be dirt in them. Get to where you can shine a light straight in and I bet you will see dirt.
/ kubota overheat problem #3
I agree with JerryG . I used a toothpick and blow gun to clean out the fins . Makes all the difference . Try the trouble light thing to check it . You'll be supprised .
/ kubota overheat problem #4
If your radiator is in the back and the battery is "in front" of it, remove the battery and clean that area. On my BX 2200 I found that there was a bunch of S*** behind the battery because of the suction created by the fan......I had a beginning heat problem and once I removed the battery and vaccuumed the radiator....temp dropped right down to normal. Hope this helps!
/ kubota overheat problem #5
I posted the following on 9/1/04, hoping it would help anyone else which may be having this problem.
<font color="blue"> </font> Two weeks ago I noticed my coolant ran out through the overflow valve on my BX22(210 hours). I had mowed about 3 acres and never noticed the temp gauge higher than usual. I always clean the screen under the steering wheel and the (pull out) screen in front of the radiator when I see any type of buildup. I didn't get a chance to check everything before my next mowing. I mowed about 2 acres and noticed the gauge just a bit higher but not to a point which worried me. I turned off the mower and again lost more coolant(which did not overflow while I was mowing). This is when I knew I needed to check things out more carefully. Both screens were clean but I took them off regardless. I found my radiator totally blocked with fine grass and dust approximatley 4/16 of an inch. I haven't checked the manual to see for any detailed info to check for this blockage (it may be in there); however, I cleaned this thoroughly and haven't had any trouble since. I just wanted to put this information out for anyone who doesn't have time to clean every single ity bity part of their tractor before washing, waxing, buffing, armour-all the tires, clean the grass off the bottom of the MMM then polishing the bottom of the MMM and painting with vegetable oil or (that paint some of yall have used from TSC), greasing all moving parts and kissing your baby good night. I wish I had that kind of time but I don't. Yall have a good day and keep the shiny side up, of course some of yall have shiny tractor bottoms too. <font color="blue"> </font>
/ kubota overheat problem #6
You don't want to do this if you have an aluminum radiator..........Spray some of that cheap $1 a can oven cleaner in the fins. Wait about 3-4 minutes. Than wash out with the garden hose. The black dirt will flow out like crazy. Rinse everything off good. AGAIN don't do this on an aluminum radiator.
/ kubota overheat problem #7
I cleaned mine up very good yesterday morning. i noticed this weekend that it didnt cool as god as usual even after i would clean the screen. i use a engine cleaner from wal mart with my air compressor and a little soapy water. then rinse it with a water hose.
it's pretty amazing how much trash gets between the fins.
Now i haven't tried this on my tractor yet but i use DOW bathroom cleaner on my vehicle engines. it will flat amaze you how well those scrubbing bubbles clean your engine. it has to be DOW i have found. a used car dealer gave me that trick and boy does it work.
I would bet it would work on a radiator.
Hey guys, thanks alot...YOU were all right so far, those fins are filthy...so will report if cleaning helps the overheat problem..have passed it along to my buddies as well...but I don't understand (I am a horseman, NOT a mechanic!) why it doesn't overheat just running it all day, say towing a fert wagon or something?? and sorry about the delay in responding, could not figure out how to post a reply.
/ kubota overheat problem #10
( and sorry about the delay in responding, could not figure out how to post a reply. )
You mean the link called <font color="blue"> Reply </font> didn't give you a clue? /forums/images/graemlins/grin.gif
/ kubota overheat problem #11
</font><font color="blue" class="small">( ..but I don't understand (I am a horseman, NOT a mechanic!) why it doesn't overheat just running it all day, say towing a fert wagon or something?? )</font>
When the area between the flus get dirty, air is restricted from flowing between them. the coolant is hot and just stays hot and as air is further restricted it gets hotter. the flow of air cools the radiator thus cooling the coolant in it.
as long as you have good flow of air ,coolant and no other obstructions in your coolant system it will run all day even under a load and not get too hot.
The one fault i have found with my kubota is how small of a radiator it has . but then i think a diesel runs cooler than a gas engine and doesnt require a huge radiator to cool coolant.
so keep it clean and it will run good and cool for you. /forums/images/graemlins/grin.gif
yea, i saw 'reply' and i found I have to click it three or more times to get the reply box, the rest of the time i get my log in page repeatedly...old computer i guess..and have cleaned up the fins, found my bushhog has a bent shaft in the gearbox which put more load on the tractor, and really think my 5.5 hog is a tad too big, so combined with the other problems, well...will use it this week, fixed, so will see what happens...have n't heard from my buddies withtthe same overheat, so who knows? thanks again ya'll
/ kubota overheat problem #13
You got me to looking and yep, mine was a touch plugged. About 1" high of blockage behind the battery. I used a shop vac to pull it out.
Thanks,
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
Toro LX460 Riding Mower (A65579)
Toro LX460 Riding...
1963 Ford Falcon (A62613)
1963 Ford Falcon...
John Deere BW17029 Tractor Bucket (A65640)
John Deere BW17029...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
