Kubota or mahindra
   / Kubota or mahindra #211
Neither my 2002 M9 with 6000 hours or my 2004 M9 with 3000 hours have ever been split and that is all farming hours. Do my own services too.
   / Kubota or mahindra #212
Anyone who thinks lighter castings on machinery is better, doesn't know much about casting durability on machinery.
SR
   / Kubota or mahindra #213
SR
Lighter being better isn’t a sure fire measure but neither is heavier being stronger. Something can be heavy and still suck.
   / Kubota or mahindra #214
I think it all comes down to the design and where the stress points are. I will reference this older thread as an example of a heavy casting but bad design:
   / Kubota or mahindra #215
sign me up for heavier
   / Kubota or mahindra #216
You can buy whatever size kubota you want. If you want a 4000 pound Kubota you can get that. But it’s probably going to be 50-60 hp opposed to 40. Is that supposed to be a bad thing? As already mentioned comparing tractors by HP is pretty meaningless. You wouldn’t separate pickups by hp opposed to class would you?
   / Kubota or mahindra #217
I snapped off the lower arm connection point casting on my Kubota L4060 this summer pulling old fence posts.
In my case, I was applying a load to the 3pt arms that it was not designed to handle and I should have known better.
That mistake cost me 2 Grand.
   / Kubota or mahindra #218
🤑 Why didn't you chain them around your drawbar instead? Or better yet your loader?
   / Kubota or mahindra #219
The castings on our 1950 John Deere B were a lot more refined than the ugly castings on a Mahindra made in India. The TYM made Mahindras don't seem to suffer the same affliction.
   / Kubota or mahindra #220
Nope not bad at all.
Given other things equal, I will always prefer more weight over less, because maybe you don’t know this, but weight is traction. Weight in the proper place is also stability with something like a raised loader.
Tractors are built for traction and stability.
I see 1-2 threads literally every week about traction and/or stability.
I think weight and HP, outside of build quality, are probably 2 of the most important considerations in a tractor purchase.
1992 CATERPILLAR 14G MOTORGRADER (A52709)
1992 CATERPILLAR...
2017 Freightliner M2 106 Terex Commander C4047 Insulated Digger Derrick Truck (A55973)
2017 Freightliner...
2020 Deere 50G (A53317)
2020 Deere 50G...
2018 CATERPILLAR 289D SKID STEER (A52709)
2018 CATERPILLAR...
2017 Ford F-150 Ext. Cab Pickup Truck (A55973)
2017 Ford F-150...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
