Kubota or mahindra
   / Kubota or mahindra #211
Neither my 2002 M9 with 6000 hours or my 2004 M9 with 3000 hours have ever been split and that is all farming hours. Do my own services too.
   / Kubota or mahindra #212
Anyone who thinks lighter castings on machinery is better, doesn't know much about casting durability on machinery.
SR
   / Kubota or mahindra #213
SR
Lighter being better isn’t a sure fire measure but neither is heavier being stronger. Something can be heavy and still suck.
   / Kubota or mahindra #214
I think it all comes down to the design and where the stress points are. I will reference this older thread as an example of a heavy casting but bad design:
   / Kubota or mahindra #215
sign me up for heavier
   / Kubota or mahindra #216
You can buy whatever size kubota you want. If you want a 4000 pound Kubota you can get that. But it’s probably going to be 50-60 hp opposed to 40. Is that supposed to be a bad thing? As already mentioned comparing tractors by HP is pretty meaningless. You wouldn’t separate pickups by hp opposed to class would you?
   / Kubota or mahindra #217
I snapped off the lower arm connection point casting on my Kubota L4060 this summer pulling old fence posts.
In my case, I was applying a load to the 3pt arms that it was not designed to handle and I should have known better.
That mistake cost me 2 Grand.
   / Kubota or mahindra #218
🤑 Why didn't you chain them around your drawbar instead? Or better yet your loader?
   / Kubota or mahindra #219
The castings on our 1950 John Deere B were a lot more refined than the ugly castings on a Mahindra made in India. The TYM made Mahindras don't seem to suffer the same affliction.
   / Kubota or mahindra #220
Nope not bad at all.
Given other things equal, I will always prefer more weight over less, because maybe you don’t know this, but weight is traction. Weight in the proper place is also stability with something like a raised loader.
Tractors are built for traction and stability.
I see 1-2 threads literally every week about traction and/or stability.
I think weight and HP, outside of build quality, are probably 2 of the most important considerations in a tractor purchase.
JOHN DEERE 300 GALLON NITROGEN APPLICATOR (A52708)
JOHN DEERE 300...
1000 GALLON POWER BLAST AIR MIST SPRAYER (A52708)
1000 GALLON POWER...
LOT: Welding Accessories: (2) Auto Darkening Helmets, Welding Rods, Welding Wire, Magnetic Arrows (A59076)
LOT: Welding...
BETSTCO FMN120 -4' FINISH MOWER, 3PT (A52708)
BETSTCO FMN120 -4'...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
Suzuki Vision Quad Runner 500 (A55272)
Suzuki Vision Quad...
