kubota models m vs mx
/ kubota models m vs mx #21
The m5640sud is listed at 3858lbs, the mx5100 hst is 3774, and 3620 with gears. They also have the exact same displacement. I'm not saying they are the same, but that's actually less than a few hundred pounds. I didn't know about the 5640 when I bought my MX, but I sort of wish I had. Build your Kubota only listed the 5640 as $1000 more than my 4700. Now, there's no hydro option, so I'm still happy with my decision, but it would have been nice to try both.
i'm with you on that & am sure the OP appreciates your input hope you continue to be content with your tractor...the mx5000 was a no nonsense workhorse for me that anyone could be proud of :)
/ kubota models m vs mx #22
I just sold one last week. It was only built for a couple of years (2010-2011, I think). It was offered in response to a John Deere model that had a high "value" appeal. As such, it is a very basic HST tractor. (No draft control, jerky 3 pt. hitch, minimal OEM options available.)
Gotcha, thanks for the info.
/ kubota models m vs mx #23
what separates a m from an mx. I am in the market for something along what I see about the mx4700 or the mx5100. But when I look at tractor adds for the used ones I never know how to judge what is a good deal and what is not. M vs MX is just one of my many confusion points, Clearing that one up will help. MX 5100 appears to be what I want but don't want to buy without understanding what it is and what it is not. I moved in my thinking from L4700 to the MX ( a little heavier) just from some things I have read.
Night and day difference between an MX and M. I came close to buying a used MX5100DT w/ 844 FEL but the dealer would not throw in a brush guard, so I walked. Finally found a nice used M5040 w/ 1153 FEL and I am much happier with all the extra features. The M5040 cost more but it is worth every dime.
/ kubota models m vs mx #24
I think the best thing to do is head to your dealership and have them park an MX next to an M so you can see the difference then run both. Price was the main factor for me. The M was about $5k more than the MX and I couldn't justify it.
/ kubota models m vs mx #25
L3700SU is a tractor/loader package. The tractor itself is not much different than the L3400, but was sold couple of grand cheaper than L3400 + loader.
SU stands for Special Utility. I think all Kubota SU tractors are basically tractor/loader packages, which are a little cheaper that getting the same tractor + loader separately.
I saved about $2K buying the L3700SU vs L3400 + the same loader.
Here is more info on the L3700SU:
http://kubota.ca/en/images/db/brochures/0193.pdf
What is a L3700SU? Have never seen one around here...
/ kubota models m vs mx #26
<snip>Seems futile to find a good used one that would not wind up costing me just as much as a new one in the long term.
Depends on the USED tractor and how much YOU will use it.
For instance my uses will be a few hundred hours a year at the most.
I set my sights on getting a 40HP tractor that could lift a ton on the back w/ 4wd and FEL for under $15K. Brand had to be one of the top four.
I bought a 1995 M4700 w/ 1400 hrs, seemingly well maintained by the county. For about $12K. Lifts about 2 ton on the back and 1 ton on the FEL. I've put about $100 in it for hoses, need new front tires ?$400?. And I've put about 100 hours on it.
There's a comparable one for sale at http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=6992855 for $16.5K. A MX4700 new would cost about $25K, and that only lifts about a ton on the back.
So -
New - $25K (but a lot less power)
Used - $12K
I couldn't justify twice the cost for a few hundred hours per year. I can put a lot of maintenance into it for another $12K.
/ kubota models m vs mx #27
One thing I don't like about my MX5100 is that there is no "idiot light" for the parking brake. Do they have one on the M series? (YES- I am the idiot that forgot to release the brake.)
/ kubota models m vs mx #28
I think everyone that has switched from a geared transmission to an HST tractor needs the idiot light, it's too easy to forget when you push on the go pedal. After awhile I noticed the increased HST whine if I forgot it. It sort of functions as the idiot light for me now. I do think the MX is the best value tractor I have ever owned and the only gripes I have about it other than that are fuel consumption and turbocharger and HST whines are very load. I realize that with a turbocharged 50 HP HST tractor the trade off for fuel consumption is flexibility, ease of use, and maneuverability. It has been and is a great tractor for my needs.
/ kubota models m vs mx #29
The grand L series has a light on the dash that comes on when the parking brake is engaged. I would have to look and see where the switch is mounted.
/ kubota models m vs mx #30
Well, if it had an idiot light and IF you were like me, you'd be wishing the idiot light flashed in order to draw the absent-minded operator's attention to it.
Yes, my tractor has an idiot light for the parking brake and I've STILL managed to drive it with the parking brake engaged. :ashamed: :duh:
/ kubota models m vs mx #31
Well, if it had an idiot light and IF you were like me, you'd be wishing the idiot light flashed in order to draw the absent-minded operator's attention to it. Yes, my tractor has an idiot light for the parking brake and I've STILL managed to drive it with the parking brake engaged. :ashamed: :duh:
it's surprising how even a large red flashing light can be missed. We put one on our combines at one time due to the number of customers burning machines by driving with the parking brake engaged. We are talking tail light size flashing light. Me arresting asked us to review the new advertising video they created for the next year's model introduction. One scene showed a combine cutting directly at the cameraman with this large brake light flashing, very obvious, and embarrassing, to us engineers. Next came the parking brake interlock. Insurance companies were coming after us. After the fire problem became known they would in turn sue us to recover damages for every claim. All settled out of court and safety recall implemented. Interlock or audible alarm really needed. The blinking light on my L5740 is for decoration only. The alarm on the M135GX is an attention getter. The park position on our John Deeres is my favorite.
/ kubota models m vs mx #32
well said & useful to know. maybe a bit off topic and subject for another thread good luck to OP glad to hear he is satisfied with his decision
/ kubota models m vs mx #33
The MX's are really good value tractors, not perfect, but for the price a true useful utility tractor. Dollar for dollar it is probably the best value small tractor I have ever owned.
/ kubota models m vs mx #34
i would totally agree having owned one myself (5000) should i want to spend more on machinery, i'm glad i went the M route rather than Grand L consumers are fortunate to have so much available in K's line....it's just about matching needs/budget to the right machine. forums like this are great for that
/ kubota models m vs mx #35
I totally agree. I also believe in the Utility and CUT tractors the range of use is much broader than say a 300HP 4X4 AG Tractor. So it takes a lot of models that are very similar to fill all the gaps. For example, I'm a bells and whistles guy, if I'm spending the money I want the comforts and ease of use. Other members on TBN could care less about that and simply look at weight/HP.
I am really glad I asked the question concerning M vs MX. There is even more to it than I thought. I have learned much from the responses to this thread. The over lap between all these models in the 35HP to 55 or so is still dizzying but I am now much better able to jump on a deal if I find it.
/ kubota models m vs mx #37
It is confusing, I grew up on a farm and thought I knew a little about tractors until I started looking to buy a new one several years ago, man I was lost; still don't know all I should.
/ kubota models m vs mx #38
Yeah, bad enough if you are set on one color. If you are color blind then it gets very, very confusing!!!
/ kubota models m vs mx #39
I'm not sure tha answer to "what's the difference between a M and a MX" was addressed. I believe the consencus is the MX is cheaper than the M. Is the MX a price cutter tractor and the M a better built tractor?
/ kubota models m vs mx #40
Some years ago Kubota MXs were described two ways:
MX is a de-accessorized Grand L, priced to sell at a utility tractor competitive price, rather than a de luxe price.
MX is an 'L' in front and an 'M' in the rear.
Gives you some idea -------
L's are small to mid-size. MX's mid-size. M's are the next heavier Kubota tractor category.
All Kubotas are built the same: GUD.
2014 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRACTOR (A59911)
2014 FREIGHTLINER...
2017 Ford Escape 4WD SUV (A61574)
2017 Ford Escape...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2006 Toro SandPro 2020 Bunker Rake (A61572)
2006 Toro SandPro...
