Kubota Model Numbers
/ Kubota Model Numbers #1
Jag
Central Arkansas
Kubota /L2650/ LA450/B4690 -- John Deere 450 Dozer
Does anyone have at least a rough breakdown on the Kubota model numbers changes and about what model year? A friend asked a question about it and I really did not have a good answer. I ran a search on it and did not find a answer. This is mainly for the L series. Thanks for the help guys.
/ Kubota Model Numbers #4
Jag -
Another source of such info can be found at:
http://www.zimmererkubota.com
Look in the left-hand scroll box for "Kubota Tractor History" and you will find links to model lists for the B, L and M series tractors. Not completely up to date, but a lot of models nonetheless.
/ Kubota Model Numbers #5
Harv - Actually, kubotatractors and zimmererkubota are the same site.
Mark
/ Kubota Model Numbers #6
Oops!
Just realized the address I just gave you is an alias to the same site Mark referred you to. /w3tcompact/icons/blush.gif
Hard to get ahead of that Chalkley guy, even in his weakened condition. /w3tcompact/icons/smile.gif
/ Kubota Model Numbers #7
Holy Cow, Mark!!!
There couldn't have been 2 minutes between my first and second posts here -- and you beat me again! /w3tcompact/icons/shocked.gif
You sure you aren't sipping espresso from that giant cup of yours?
/ Kubota Model Numbers #8
Harv, I'm impersonating the hare tonight - I'll be the tortoise when I wake up later this morning. This is the latest I've stayed up since my "incident". So I'm going to bed. I'm 3 hours ahead of you, you know. (Maybe that's why I was so fast... /w3tcompact/icons/wink.gif)
Mark
Thanks for the info, guys that was fast as always...
<P ID="edit"><FONT SIZE=-1>Edited by JAG on 8/30/00 10:15 AM.</FONT></P>
/ Kubota Model Numbers #10
Jag - There is another factor in figuring out hp for each model - especially in the L's. Some model numbers correspond to Gross HP, some to PTO HP and some to Net HP.
A reason behind the confusion may be that in the early '80s Kubota's model numbers corresponded roughly to Gross HP, which included everything the engine was doing, including heat and noise.
The L345, for instance had 34.5 gross, and 28 PTO hp, roughly 20% less. But they took some heat from tractor purists who were more interested in ratings based on power available at the PTO - a more honest estimate of what work a tractor could be expected to do besides move itself around.
So in the mid '80s Kubota brought out some L-xx50 tractors where the model number was tied to PTO hp. The L-3750 had 37.5 hp at the shaft, etc.
This means that there are some older L-series tractors with lower numbers which have more power and weight than some newer ones with higher numbers.
Around the early '90s the new models started being named with digits midway between gross and pto - called the "net" hp. I think this continues through L's and M's today.
Hope this is relevant to your question.
/ Kubota Model Numbers #11
Re: Kubota Model Numbers...Harv.
I like the Kubota pulling your name,so how did you do that? /w3tcompact/icons/smile.gif
Take care and stay /w3tcompact/icons/cool.gif
Thomas..NH
/ Kubota Model Numbers #12
Thomas -
Using one of Muhammad's shortcuts, anyone can include an image anywhere in your post or even in your signature. All that you need is an image on a server that you can refer to. Just use the image tags, as described on the FAQ page, and put the address of your image where it says "url". For example, the URL for my signature is "http://www.acknowledge.com/kubota/HarvSig.gif". (Please don't use that one -- it would be too confusing. /w3tcompact/icons/crazy.gif
Word of caution -- make sure any images you include in a post or a signature have a very small "footprint". That is, don't use an image that will take any significant time to download over a modem. The board gods would be angry. /w3tcompact/icons/mad.gif
Hope that helps.
ATS ATS-PC90 Heavy Duty Plate Compactor (A62679)
ATS ATS-PC90 Heavy...
New/Unused Quick Attach Pallet Fork Frame (A65583)
New/Unused Quick...
Rock Hammer for Excavator (A65579)
Rock Hammer for...
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
2018 FREIGHTLINER M2106 DUMP TRUCK (A63276)
2018 FREIGHTLINER...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
