Kubota Mechanical Snow Blade
/ Kubota Mechanical Snow Blade #1
J.Walker
Bronze Member
Bristol Mountains, Western NY.
Kubota L3130 and BX 2360
I noticed a mechanical snow blade offered by Kubota. The snow blade attaches to the FEL. It's offered in a 60 and 72" size.
I'd like to use it on my L3130.
So who has one and is it worth the cost?
/ Kubota Mechanical Snow Blade #2
For a SSQA FEL?
/ Kubota Mechanical Snow Blade #3
I had a six ft.sub-frame mounted on my previous L3130 HST and it was a good fit.When I traded to my L4240 HSTC I installed a FEL mounted 8ft.Curtis(old truck plow).I much prefer the FEL mounted plow.
I had the third function(to angle) on both tractors.Manual angle is o.k. but the hydraulic angle is much easier to use.
My tractor has the SSQA so it's an easy change to the bucket if needed.
/ Kubota Mechanical Snow Blade #4
I have the snow blade.
I also bought the quick detach option and have it mounted to the front end loader so I can easily swap from the bucket to the blade and back in a matter of minutes. I recommend added this option...:thumbsup:
/ Kubota Mechanical Snow Blade #5
J Walker, if your L3130 has the SSQA, like mine does, go for a QA blade. It is easy to adapt the bucket tilt hydrualics to pivot the blade and you're able to choose from many blade options, and avoid the problems that having the blade WAY out in front entails. I got a Horst Welding 78" blade, which I have yet to use, but I think it will work very well.
2 1/2 ft x 2 1/2 ft Metal Cage (A61166)
2 1/2 ft x 2 1/2...
2016 Ford F-250 Crew Cab Pickup Truck (A61568)
2016 Ford F-250...
30 Yard Roll Off Dumpster (A61166)
30 Yard Roll Off...
BUHLER 2 PRONG BALE SPEAR (A62130)
BUHLER 2 PRONG...
2018 CATERPILLAR 236D SKID STEER (A62129)
2018 CATERPILLAR...
2025 Swict 84in. Skid Steer Bucket Attachment (A61567)
2025 Swict 84in...
