Kubota M9580
   / Kubota M9580 #1
davemorley
Prince Albert
kioti ck2510 hst
We can’t find a serial number on our kubota M9580 and we need a hydraulic pump, Any help, part number etc greatly appreciated
   / Kubota M9580 #3
May I ask what diagnostics were performed to determine hyd pump needing replacing? Have you checked operation of hyd relief valves?
   / Kubota M9580
Not sure what to do. It works if you run it at 2000 rpm, had new oil and new filters
   / Kubota M9580
Hi, it’s a friends tractor he has replaced all the filters and the oil. He said it only shuttles once he get to 2000 rpm…. That’s all I know
   / Kubota M9580 #7
A pump is really expensive. Much more so that a diagnostic call from an actual kubota dealer or mechanic.
Id want to be sure its the pump before I drop more than a grand for a pump and deal with the hassle of changing it
   / Kubota M9580 #8
Id want to be sure its the pump before I drop more than a grand for a pump and deal with the hassle of changing it because if you have other problems in the system, it may be a waste of money and may trash the new pump
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
2017 RAM PROMASTER 2500 CARGO VAN (A51222)
2017 RAM PROMASTER...
71052 (A49346)
71052 (A49346)
2017 HINO BOX TRUCK (A51222)
2017 HINO BOX...
JOHN DEERE 450H CRAWLER DOZER (A51406)
JOHN DEERE 450H...
2022 CATERPILLAR 306CR EXCAVATOR (A51242)
2022 CATERPILLAR...
