Kubota M9000 Air Conditioner issues
   / Kubota M9000 Air Conditioner issues #1
JeffreyOwens
Anderson, AL
Cub Cadet 3240, Kubota M9000
Can any type of ac Freon be used.
   / Kubota M9000 Air Conditioner issues #2
No, it has to be compatible. I would imagine that machine has R134 in it, I dont think it is old enough to have used R12. If it is R12 it will have to be converted to R134.
Brian
   / Kubota M9000 Air Conditioner issues #5
Well since the build start date is 1999 thru 2005 I can say for sure its NOT R12.
TractorData.com Kubota M9000 tractor information
There you go recharge wit R-134 the best way to do this is to evacuate system measuring how much was removed then vacuum system and leak check then refill with proper amount also add oil if needed. are you can use the old suicide method and buy a can and hose an charge to you think its full.
2017 Ford F-250 Enclosed Knapheide KUV Service Truck (A50323)
2017 Ford F-250...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
Unverferth Brent CPC PT 16' Disc Ripper (A50120)
Unverferth Brent...
2014 Dodge Journey SUV (A50324)
2014 Dodge Journey...
2000 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
2000 HEIL TRAILER...
2010 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2010 Toyota Tundra...
