Kubota M9000 Air Conditioner issues
   / Kubota M9000 Air Conditioner issues #1
JeffreyOwens
Anderson, AL
Cub Cadet 3240, Kubota M9000
Can any type of ac Freon be used.
   / Kubota M9000 Air Conditioner issues #2
No, it has to be compatible. I would imagine that machine has R134 in it, I dont think it is old enough to have used R12. If it is R12 it will have to be converted to R134.
Brian
   / Kubota M9000 Air Conditioner issues #5
Well since the build start date is 1999 thru 2005 I can say for sure its NOT R12.
TractorData.com Kubota M9000 tractor information
There you go recharge wit R-134 the best way to do this is to evacuate system measuring how much was removed then vacuum system and leak check then refill with proper amount also add oil if needed. are you can use the old suicide method and buy a can and hose an charge to you think its full.
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A58018)
2019 INTERNATIONAL...
2011 Ford Crown Victoria Sedan (A54815)
2011 Ford Crown...
New/Unused Electric Golf Cart (A57453)
New/Unused...
BUSH & BOG 16 BLADE DISC HARROW (A52708)
BUSH & BOG 16...
2008 International 7500 T/A Altec A77T 76ft. Bucket Truck (A55973)
2008 International...
