Kubota M9000 Air Conditioner issues
   / Kubota M9000 Air Conditioner issues #1
JeffreyOwens
Anderson, AL
Cub Cadet 3240, Kubota M9000
Can any type of ac Freon be used.
   / Kubota M9000 Air Conditioner issues #2
No, it has to be compatible. I would imagine that machine has R134 in it, I dont think it is old enough to have used R12. If it is R12 it will have to be converted to R134.
Brian
   / Kubota M9000 Air Conditioner issues #5
Well since the build start date is 1999 thru 2005 I can say for sure its NOT R12.
TractorData.com Kubota M9000 tractor information
There you go recharge wit R-134 the best way to do this is to evacuate system measuring how much was removed then vacuum system and leak check then refill with proper amount also add oil if needed. are you can use the old suicide method and buy a can and hose an charge to you think its full.
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
PICKUP TIRE CHAINS (A50854)
PICKUP TIRE CHAINS...
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
2025 GIYI Skid Steer Plate Grabber (A50322)
2025 GIYI Skid...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A51039)
2017 Ford F-550...
