Buying Advice Kubota M7060
   / Kubota M7060
I haven't bought the tractor yet, but I bought a trailer yesterday for hauling the tractor between my two farms. I pick it up tomorrow. I got a Big Tex 14GN 20+5 with megaramps.
   / Kubota M7060 #22
Ed,
My farm is just outside of Crossville. I bought my M7060HD12 last year from Plateau Kubota. My property (93 acres) sounds similar to your in that I have some pasture and some areas that need reclamation. I purchased the ROPS model as I have too many trees that I have to mow around/under to even consider a cab. I also went with an extra remote, filled tires, cast wheels and the wider R1 tires. As for implements, I purchased a LP 3584 box blade, Titan 1606 rotary cutter and an Everything Attachments 7500HD auger.
As for the tractor, the shuttle shift is OK but not as precise as HST. I was cutting on some pretty steep hills last week and there was some pucker factor shuttling b/t forward and reverse on the hills. I definitely needed good brakes when getting to the end of the field. I traded HP for HST. I considered the MX5800 as well as it would have suited my needs as well. The 7060 is decent on fuel. However, in the 37 hours of use, it's tended to regen about every 12-15 hours.
As for implements, I cannot recommend Titan cutters nor the dealer I purchased from (not Plateau Kubota). The dealer delivered the cutter on a trailer behind a car and had no idea how to setup once delivered. Never said anything about adjusting the slip clutch which was needed after delivery. The cutter came to me with no shaft guard, stripped threads where grease fittings fell out and just isn't as durable as advertised. I opted for the chain guards and have already bent those mowing to the point the chain is making contact with the blades. For $700 more, I could have gone with Bush Hog brand which is what I should have done. Moral of the story, stay with top tier products as you get what you pay for.
Good luck with your purchase. I'm interested in hearing what you decide.
   / Kubota M7060
I bought my tractor today. M7060HD12, 4WD, 12 speed, open station, LA1154 FEL with standard valve, 3rd function valve kit, grill guard, radial ag tires, rear wheel weights, filled rear tires, Land Pride RCR2672 rotary cutter with chains on front and back, Titan Implements industrial root grapple (not Titan attachments, Titan Implements is a family owned company in Decatur, TN). I pick it up in three weeks.
   / Kubota M7060 #24
The mice started in on my new tractor chewing up the Rubber floor, put peppermint oil in the cab, order two walk the plank mouse traps.
   / Kubota M7060
Darn mice. I have a rat problem around my barn because my wife has a lot of chickens.
   / Kubota M7060 #26
I would suggest R1 tires and a cab if you will be utilizing the tractor mostly on the 35 open acres. I tried to justify a cab but 95% of my work will be in among trees.
   / Kubota M7060 #27
Big Tex has a variety of trailers. Anyone looking at buying a new tractor package deal with bottom of the line trailer needs to visit a Big Tex dealer and compare.
We bought the Big Tex 14ET with mega ramps. There is a Big Tex mfg facility just down the interstate from us.
2015 Ford F-350 4x4 Pickup Truck (A54814)
2015 Ford F-350...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
2018 FONTAINE TRAILER CO. 50 STEP DECK LOADER TRAILER (A58214)
2018 FONTAINE...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
2017 Freightliner MT55 Step Van (A56858)
2017 Freightliner...
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
