Dirt Moving Kubota M7060 clutch functionality
/ Kubota M7060 clutch functionality #11
all the more reason to go w/hyd shuttle upgrade over conventional single dry plate clutch. big advantage...from what i understand, the design has been around a long time. don't care to split a tractor, never will
thankfully, shifting standard is easy for me, so it's the best of 2 worlds w/o the HST etc. everything has it's place
Yes big advantage. I’m even more happy now that I got hydraulic shuttle.
/ Kubota M7060 clutch functionality #13
Pull the shuttle into neutral as you coast into the pile, curl bucket, pull shuttle back in reverse and go. No pedal needed.
Same as dumping, pull into neutral, dump bucket/shake etc, pull shuttle back in reverse and go.
I load manure from pack or pile into spreader, round bales on and off wagons etc. hardly touch the clutch pedal.
/ Kubota M7060 clutch functionality #14
Farmer495
You didn't mention engine speed in your reply. Do you utilize foot engine speed control to lower engine rpm's when changing tractor directions? Lower engine speed lowers stress on tractor drivetrain when changing tractor directions
/ Kubota M7060 clutch functionality #15
good point, i come to nearly full stop & rpm's low when using shuttle.
/ Kubota M7060 clutch functionality #16
Farmer495
I use foot throttle exclusively for loader work, hand throttle isn't used for loader work. I am off throttle (idle RPM) whenever engaging shuttle. Engine can be revved up as needed with foot throttle whether for more hyd power or speed, or to increase travel speed.
I also use low range at all times when doing dirt or manure work. I will use high range on hard ground handling round bales.
/ Kubota M7060 clutch functionality #17
There is NO clutch wear because there is NO clutch. It's a multiplate wet pack just like in a motorcycle. Myself, I USE BOTH, depending on what I'm doing. 6000+ hours and no adjustment tells me it's fine and I farm with both of mine.
There are clutch discs and wear discs in a wet clutch (just like a motorcycle)
And they do hold up much better than a dry disc, but they can wear out, just like a motorcycle clutch if abused. (I have replaced wet clutch on a motorcycle before)
/ Kubota M7060 clutch functionality #18
So have I. The issue is a wet multiplate clutch will last exponentially longer.
PREVIEW DATES AND TIMES (A61165)
PREVIEW DATES AND...
New Holland T2420 (A53317)
New Holland T2420...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
Coats 5060AX Rim Clamp (A61307)
Coats 5060AX Rim...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A60736)
2008 TEXAS BRAGG...
