Kubota M7040 seems to ride rough??
   / Kubota M7040 seems to ride rough?? #1
tom4018
South Central Ky
Kubota M7040HD
For those that have a Kubota M7040 do you feel they ride a little rough? Comparing to my old Ford 4630. Need to double check tire pressures for one but I guess that is all I can do.
   / Kubota M7040 seems to ride rough?? #2
Compared to the N.H. & Deere it is a lighter tractor. If you're talking about the ride on pavement or hard packed dirt it may just be the tread on the front tires versus a two wheel drive.
   / Kubota M7040 seems to ride rough?? #3
Check tire pressure, my Kubota was delivered with a lot of air in the front tires so they would resist the weight of a full bucket. Made it so rough I could hardly rake with it.
I lowered the pressure a lot and it is better, if I'm gonna move a lot of gravel etc I air them up a few pounds.
Fronts have 24 psi and the rears have 16 psi. Dealer had the rears too full of fluid and I let some out. Too muddy to tall much about it now.
   / Kubota M7040 seems to ride rough?? #5
You shouldn't have more air then needed to keep the bars in full contact with the ground. To never have the the front tires squish or flatten when loaded means you might have to much air on the rears it sounds like you might have to much air.
   / Kubota M7040 seems to ride rough?? #6
Art's advice is good, pressure numbers will differ between tractors as its related to how much weight is on them. Mine I'm down around 6-10 psi up front when haying with my loader off, as high as 20 doing loader work.
   / Kubota M7040 seems to ride rough?? #7
I noticed that my M5040 rides like a buckboard as well. I have yet to check the tires, although they seem a little overinflated. Especially in the rear. They're full of fluid as well.
24in Tractor Backhoe Bucket BT4555 (A52748)
24in Tractor...
2012 Chevrolet Malibu Sedan (A50324)
2012 Chevrolet...
2018 New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
2018 New Holland...
Year: 2007 (miles exempt on title) Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: (A51694)
Year: 2007 (miles...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
2015 FREIGHTLINER CASCADIA DAY CAB (A52577)
2015 FREIGHTLINER...
