Kubota M7040 hydraulic squeal
   / Kubota M7040 hydraulic squeal #1
nauxier16
Red Bush, Ky
2013 Kubota M7040 4wd Hydraulic Shuttle
Hey Guys I have noticed a short noise/squeal from the hydraulic system when I start up my Kubota M7040, all hydraulics work as they should. The sound doesn稚 seem to cause an issue, just wondering if someone can let me know what it is. I have a short video of the sound if that would help I can send it or attempt to post it here. Thanks!
   / Kubota M7040 hydraulic squeal #2
Noticed a squeel noise starting my L3940 the other day. Turned it off and restarted with no noise. Did not notice the noise starting it today.
   / Kubota M7040 hydraulic squeal #3
My M7040 does it too, and it's worse if you hydraulic fluid level is lower than it should be. Check you fluid level. Low hydraulic fluid accentuates the problem I found.
Thanks for the replies! The fluid is just at the full mark, may even be just a hair over full.
   / Kubota M7040 hydraulic squeal #5
Try dropping the three point hitch a little;if it goes away it's out of adjustment.Squeal is from the relief.
Thanks nybirdman, I tried that and with no pressure from the loader. I was thinking like you said that maybe the feedback rod was out of adjustment but it does it with the 3pt lowered also
   / Kubota M7040 hydraulic squeal #7
Sure it’s not a loose belt ?
Yeah definitely not a belt issue, doesn稚 really sound like a belt either, sounds like it痴 coming from under the seat/ pump area to me
   / Kubota M7040 hydraulic squeal #9
Happened to my kabota it was a loose /bad water pump!
   / Kubota M7040 hydraulic squeal #10
Check the hand knob control valve under the seat that controls speed of the 3. hitch
Electric Concrete Mixer (A51573)
Electric Concrete...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A53472)
2004 Capacity Yard...
2022 Freightliner M2 106 Medium Duty Rollback Truck, VIN # 1FVACXFC5NHNM7347 (A51572)
2022 Freightliner...
