Kubota M6800
   / Kubota M6800 #1
CAH2873
Hello- I have a Kubota M6800 2wd that has an issue with the 3pt Hydraulic Lift. When I move the lever all the way up, the arms come up and then it binds up as if the relief valve does not kick in. I then move it slightly downward until the noise quits. The problem with this is that having a box blade on the back of it and when I lower the lever down to the neutral position, the implement will drift downwards. Can anyone help me out on how to correct this issue?
   / Kubota M6800
Just went and look at the Feedback Rod. It is broken in half. Need to get it replaced.
   / Kubota M6800 #4
Squealing when 3 pt is fully raised sounds typical when feedback rod needs adjustment
this is TBN forum working at it's best, an informative reply that quickly solved the OP's thread w/o diversion.
good to see this at work, good luck w/the repair
(4) STEEL CARTS (A51248)
(4) STEEL CARTS...
RCcar RC-G4.0 Electric Golf Cart, NEW! (A52384)
RCcar RC-G4.0...
2021 PETERBILT 567 DAY CAB (A53426)
2021 PETERBILT 567...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
