Kubota M6800
/ Kubota M6800 #1
CAH2873
Member
Hello- I have a Kubota M6800 2wd that has an issue with the 3pt Hydraulic Lift. When I move the lever all the way up, the arms come up and then it binds up as if the relief valve does not kick in. I then move it slightly downward until the noise quits. The problem with this is that having a box blade on the back of it and when I lower the lever down to the neutral position, the implement will drift downwards. Can anyone help me out on how to correct this issue?
/ Kubota M6800
Just went and look at the Feedback Rod. It is broken in half. Need to get it replaced.
/ Kubota M6800 #4
Squealing when 3 pt is fully raised sounds typical when feedback rod needs adjustment
this is TBN forum working at it's best, an informative reply that quickly solved the OP's thread w/o diversion.
good to see this at work, good luck w/the repair
2005 Isuzu NQR 4 door box truck with folding gate (A63118)
2005 Isuzu NQR 4...
2014 Freightliner Bucket Truck (A63118)
2014 Freightliner...
New/Unused Solid Backing Plate (A61166)
New/Unused Solid...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
2015 SHOE1999 SER (A61569)
2015 SHOE1999 SER...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
