Traction Kubota M6800 With Cab...Front Differential Hard to Lock In
   / Kubota M6800 With Cab...Front Differential Hard to Lock In #1
treedawg
Dublin, GA
Kubota M6800, Yanmar YM2000
Been really difficult to operate the lever to lock in the front differential on my M6800 with cab. I briefly got under the tractor tonight and couldn't see anything bent or broken. I sprayed everything with a light lubricating spray while I was under there but didn't notice any improvement.
Help.....
td
   / Kubota M6800 With Cab...Front Differential Hard to Lock In #2
It was quite a PITA to get my M6040 into 4WD until I had operated the lever many times. Your situation sounds like mine - its simply a matter of new gears, levers & systems meshing, mating and operating together. While pulling on the lever - gently shift the tractor from forward to reverse and allow it to move slightly in both directions. Time & use should make this operation improve.
   / Kubota M6800 With Cab...Front Differential Hard to Lock In #3
May not apply since it's a much smaller tractor, but on our B2910, a little reverse pedal to engage the front axle and little forward pedal to disengage seems to help quite a bit.
   / Kubota M6800 With Cab...Front Differential Hard to Lock In #4
If you have a loader on raise the front wheels slightly to take the pressure off of them, it should slide in a lot easier
   / Kubota M6800 With Cab...Front Differential Hard to Lock In #5
engage while in motion
   / Kubota M6800 With Cab...Front Differential Hard to Lock In #6
ZETOR 4340 TRACTOR (A57192)
ZETOR 4340 TRACTOR...
2019 Ram 1500 4x4 Crew Cab Pickup Truck (A55852)
2019 Ram 1500 4x4...
Auger Skid Steer Attachment with Bits (A55851)
Auger Skid Steer...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
EZ loader trailer (A56857)
EZ loader trailer...
2000 GULF STREAM CONQUEST (A57192)
2000 GULF STREAM...
